Go to Post FIRST Isn't just about the robots, it's about Gracious Professionalism, co-opetition, and outreach also. - Julia Magoolia [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Programming
Unread 27-09-2008, 00:27
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
[OCCRA]: OCCRA 2008 Line Follower - Program 2
This program demonstrates line tracking on a white poster board surface with black tape. Please see powerpoint document that explains the VEX line follower algorithm with pictures of the robot sensors and motor configurations. This program will need to be modified if you plan on using it for line tracking on a dark playing field with white tape. The algorithm works but your robot mechanical design also interacts significantly with the operation of this algorithm. You need to tune or calibrate the speed variables for you own robot. Your robot may even need to have significant mechanical modifications in order to line track easily (ie. omni-wheels, ball casters, reduced friction)
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
[OCCRA]: 2008 OCCRA Easy_C Programming Template marccenter OCCRA Programming 2 22-11-2008 22:11
[OCCRA]: 2008 OCCRA VEX Carpet Playing Field - Home Depot marccenter OCCRA Programming 1 06-11-2008 09:57
[OCCRA]: OCCRA 2008 Line Follower - Program 1 marccenter OCCRA Programming 0 18-09-2008 11:32
Help With Line Follower computerwiz514 Programming 3 24-06-2008 13:35
Vex line follower sensor kit program jbill30 Programming 5 12-05-2006 14:43
