Go to Post This pic became proof that engineers should never give up thier day jobs! :p - Jay H 237 [more]
Unread 27-09-2008, 23:23
MarkO's Avatar
MarkO MarkO is offline
AKA: Mark D. Overholser
FRC #0957 (WATSON Robotics team)
MarkO is an unknown quantity at this point
Re: Control Robot with Computer
Originally Posted by Sykan View Post
Hello,
I was wondering if there was a program out there that could use a computer interface to control a 2008 robot's vecs and relays to test connections. I know easy c had one of these programs called on-line window. Are there any others?
Thanks in advanced,
~David E
Hello, I am the one who Reverse Engineered the Vex On-Line Code for EasyC 2.x, mainly because more users of Vex seem to have Version 2.x, but also because the Vex version of the On-Line Code for EasyC Pro seems broken (see Post 23).
Have you tried the FRC On-Line Code and On-Line Window in EasyC Pro (v3.0)??
I don't have access to the FRC Controller right now, but you might load up the FRC On-Line Code and On-Line Window in EasyC Pro and see what Inputs and Outputs do what.
Better yet would be get a LOG of the Data coming from the FRC Robot Controller. You can do that by making a "Serial Port Sniffer", or to load the FRC On-Line Code and On-Line Window in EasyC Pro, get it it communicating, then Use the Task Manager to kill the EasyC On-Line Window and Load a Serial Terminal Program, with settings at 115200, 8N1. Don't close the On-Line Window with the "Close" Button or the Exit, because it will send the Stop Command to the FRC Controller (I assume this because it does to the Vex Controller).
I can easily merge the changes I made to the Vex Default Code to the FRC Default Code and change it to the EasyC Pro style messages, but I don't know if the Data Format is correct.
Re-Install Windows with Inventor on Computer DMetalKong Inventor 3 03-06-2008 08:14
Attn: People talented with computer programs Jevin H Chit-Chat 2 05-12-2007 14:16
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
Computer with multiple hard drives question. Elgin Clock Technical Discussion 2 03-12-2004 11:41
Computer control maDGag Programming 1 27-12-2002 01:13
