Go to Post do the math, then use the math to go for total overkill. - pfreivald [more]
Unread 23-06-2002, 22:58
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Caster Modification
Posted by Josh Vetter at 1/15/2001 2:13 PM EST
Student on team #548, Robostangs, from Northville High School and BOSCH.
Are we allowed to modify casters to make them larger? The list of additional hardware says that we can use any amount of casters, up o 3in., in dia.. Is it legal to remove the wheel and plates on the sides, machine our own side plates, and replace the 3in wheel with another one, ie 6in wheelchair wheel? Essentially, we would only be using the swivel and the mounting bracket from the 3in caster.
#0047 (ChiefDelphi)
Re: Caster Modification - Yes
Posted by Dodd Stacy at 1/15/2001 2:26 PM EST
Engineer on team #95, Lebanon Robotics Team, from Lebanon High School and CRREL/CREARE.
In Reply to: Caster Modification
Posted by Josh Vetter on 1/15/2001 2:13 PM EST:
: Are we allowed to modify casters to make them larger? The list of additional hardware says that we can use any amount of casters, up o 3in., in dia.. Is it legal to remove the wheel and plates on the sides, machine our own side plates, and replace the 3in wheel with another one, ie 6in wheelchair wheel? Essentially, we would only be using the swivel and the mounting bracket from the 3in caster.
Yes, as long as you work with parts and stock from the kit or the list of additional materials. You can also make your own casters all the way from scratch, with the same limitations. Good luck.
Dodd
[IMG] code is Off
Building a better caster. Madison Technical Discussion 14 16-01-2003 22:53
Wheel Hub Connectors for Skyway Wheels Wayne C. Kit & Additional Hardware 16 10-01-2003 07:16
Modification on the Torque motor? archiver 2001 0 23-06-2002 23:45
What else do we want? archiver 2000 63 23-06-2002 23:19
