Go to Post NOOOOOOOOOOOOooooooo!!!!! I hate regolith. - apalrd [more]
Unread 29-09-2008, 13:58
darthfroggy darthfroggy is offline
FRC #1525
darthfroggy is an unknown quantity at this point
Programming Problem
Hey Guys....
I'm new to the programming aspect of FIRST and had some quick questions. We're trying to hook up a robot from past years to the old control boards. Can I tether a robot from 2006 to a control board from 05? Is the code stored on the robot or is it on the control board. Any advice as to how to get past years bots running will be helpful. Thanks A lot in advance
---Elmo
-Team 1525 WarBots!
Unread 29-09-2008, 14:23
Happy Birthday! EricH EricH is online now
Re: Programming Problem
Originally Posted by darthfroggy View Post
Hey Guys....
---Elmo
-Team 1525 WarBots!
The code is stored on the Robot Controller. As far as I know, it is possible to tether an '06 RC to an '05 Operator Interface. They aren't that different--I think it's mainly memory space on the RC.
Unread 29-09-2008, 14:53
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
As Eric said, the 2005 Operator interface is compatible with the 2006 Robot Controller, and the code is stored in the Robot Controller. The latter fact probably won't be of much use to you, however, as the code is only stored in compiled form. You can use a special tool to extract it from the robot for back up purposes, but you won't be able to read or edit it unless you're keen on working in PIC assembly or running it through a decompiler and trying to make sense of it. If your team doesn't have the source code for the old robot, your only option is to start from scratch with the 2006 default code.
Unread 29-09-2008, 17:50
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Just to be clear, tethering should be okay. I didn't deal directly with the 05 robot, but as I recall we were using the 05 robot as a test robot in 06 and maybe 07. But if you are using the radios, there were some changes, but I think it was between 07 and 08? Also, with the radios, the robot and controller need to have the same number frequency, which tethering will help set.
Don't hit the "prog" button on the robot controller -- that clears the program!
If you lose the code, or want to try new stuff, Kevin.org is still around, with codes going way back in time. (Not the Kevin above.) His "example" codes are complete, but you'll have to use MP-Lab to compile them. His basic codes have simple joystick driving available, but obviously anything else you'll have to write for.
Unread 29-09-2008, 18:03
I think you're right as to radio change. If not, it was between '06 and '07. Either way, for an '06/'05 interface, it doesn't matter. Just make sure you have the right radio on the right end!
Problem in Pneumatics programming beefy23 Programming 11 31-03-2008 14:37
PROGRAMMING PROBLEM HELP! Chris1228 General Forum 13 09-01-2008 12:19
Easy C programming Problem fredliu168 FIRST Tech Challenge 6 19-11-2006 22:44
C programming problem... wasabi824 Programming 5 08-02-2004 01:04
programming problem gthakore Programming 16 20-04-2002 12:21
