Go to Post The energy source of the future is brain power. - Michael R. Lee [more]
Unread 29-09-2008, 14:31
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: drivetrain idea (comments please)
I would also agree that directly driving the center wheel if at all possible is the best solution. As has been said even in some extreme case that you throw every chain, you will still be mobile and able to play the game. Also with this extra safety, you can run#25 chain or even timing belt without worrying that if one breaks you will be immobile. As far as using the kitbox in direct drive it can be as simple as having a new output shaft fabricated and making a hub for the center wheel or you could fab up completely new plates and only retain the gears form the kit transmission. Either way it is relatively easy to do and I would be willing to show you some designs I have done using kit stuff. Also I'm sure you could find a machine shop to fab up a new output shaft to keep cost down.
Mentor 2415
Unread 29-09-2008, 14:52
run the trap!!!
Team Role: Human Player
IMO if you're expecting to break #25 chain you are doing something wrong
Aside from the fact that even with 3 chains at least one wheel will always be powered if one chain breaks (I can attest to this having happened ).
Most of the off-the-shelf gearboxes (with the exception of the AM SS) require a second reduction after the gearbox, especially with 6" wheels. A second reduction will also allow you to "tune" your speed.
Just my 100 sense.
-Philip J. Fry
Unread 29-09-2008, 15:18
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
I would recommend running your chain like so:
[] = wheel
s = sprocket
c = chain
[]s
  c
  ss  (GEARBOX HERE)
   c
[]ss
  c
  c
  c
[]s
Like so:
http://andyburchardt.com/robotics_re...0Drive%201.jpg
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 29-09-2008, 17:08
AKA: Sean
I never expect to break a #25 chain in the drivetrain and in fact we ran the entire season without ever having to replace the drive chains. However, for some people who seem to still be shy about using #25 chain and reaping the great weight savings, using it in a drivetrain where the center wheels are directly driven gives an even greater incentive to use the lighter chain.
Mentor 2415
Unread 29-09-2008, 18:26
DonRotolo's Avatar
Back to humble
FRC #0832
#25 chain is more sensitive to proper tensioning. #35 allows teams to be really sloppy and still quite effective.
As to the original question: I like the idea, very similar to our 2007 robot. We used a kitbot frame with a second level of frame at the height of the top of the wheels, primarily to get a flat platform.
Your implementation seems somewhat heavier than necessary. The inner rail doesn't add much strength, it can be 1/16" wall, while the outer rail will take a beating, count on bumpers to stiffen it and lend impact resistance.
You also need to consider cross-rails from outer to inner rail, and again from one inner rail to the other - that way, an impact's force is transmitted to all four elements, not just the one impacted.
If you can mount the gearboxes lower - gotta think about the sprocket wrap - you can end up with a flat (or nearly so) platform over which your manipulator can be built.
Don
Unread 29-09-2008, 21:31
bmarick bmarick is offline
FRC #2374 (Crusader Bots)
bmarick is on a distinguished road
why did you put the gear box in between the back set of wheels?
Our team did a direct drive of the center wheel and then chain drive to connect the two outside wheels for power this worked great and we did not have to drop the center wheel.
Unread 29-09-2008, 23:22
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
As mentioned earlier, there are many different types of drivetrains and each one is unique. 4 wheel omni's, offset 4 wheel omni's, crab, rocker 6 wheel drive, direct drive 6 wheel drive, 2 wheel drive with casters, and the list goes on. It all depends on your team. We do the exact same thing this team does but we have a two stage frame:
We are able to make braces for the gearbox and we mount them lower so it IS NOT a 60 degree wrap, it is less than a 30 degree wrap. A direct drive does have its advantages and disadvantages.
R.C.
MadTown Robotics Team 1323
Unread 30-09-2008, 10:14
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
I would add a cross-brace (1x1 square tubing, 1/16" wall) to keep the frame strong and square...maybe two. They would also serve as additional mounting points for electronic boards and other devices.
As already suggested, using 1/16" wall tubing for the inner frame members is a good idea, but it may not be readily available in the 1x2 size you've chosen (not saying that it's not out there). In the case where you cannot find the 1/16" wall stuff, 1/8" wall U-channel would be a good option to save weight.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 30-09-2008, 19:14
JOhnch181 JOhnch181 is offline
FRC #1294
JOhnch181 is on a distinguished road
for cross bracing are team used a heet of 1/2" plywood to create reidgity from side to side. It has the second benefit of giving you a flat surface.
Unread 30-09-2008, 19:15
AdamHeard's Avatar
Lead Mentor
You'll really want to attach the frame members at more than just the ends. I would attach the two outer rails to each other between each wheel at a minimum, and since you're welding, it'll be real simple to do.
You can use just about any material, but if fastened in enough places, it creates a sheer-web that greatly increases the rigidity of the frame. Depending on the material, you may also need a centered crossbrace to keep it from sagging.
I have found 1/16" wall 2x1 to be very available.
Unread 30-09-2008, 20:34
definitly the cross brace or extra bracing is going to be needed. Otherwise it will bow over time. Can some one explain the degrees of rap to me. I'm still a little new to the drive train systems.
Unread 30-09-2008, 21:09
AndyB's Avatar
AKA: Andy Burchardt
You want 120 degrees MINIMUM of chain wrap on each driven/driving sprocket.
Unread 01-10-2008, 00:22
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
there will be other braces going across but their placement will depend on our design for other stuff. the reason i put gearboxes on top of the frame member is because is easier then direct drive
Jason
Unread 01-10-2008, 00:39
AKA: Sean
why not do direct drive with the super shifter? That is set up out of the box for that and gives you 2 speeds. If you wanted to you could also machine symmetrical plates for the super shifters so that each side of your frame could be identical.
Mentor 2415
Unread 01-10-2008, 02:27
I question that it is easier because then you have to worry about the chain loosing contact with either the middle or the back wheel. on the direct drive you only need to make sure the output shaft is the right length and this makes it really easy to make duplicate sides and parts cause they will all be the same size and postion. All you have to do is switch the positive and negative into your h-bridge or what ever you are using to control the motors.
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
A new drivetrain Idea? Cody Carey General Forum 55 20-08-2006 12:48
Crazy drivetrain idea lukevanoort Technical Discussion 7 26-10-2005 21:19
Crazy Idea, looking for comments archiver 1999 74 23-06-2002 22:56
Another idea looking for comments archiver 1999 16 23-06-2002 22:01
