Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Unread 01-10-2008, 10:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Hex Shafts and Bearings
We're potentially going to use hex drive shafts this year to get away from keys (that always seem to get lost at the worst times...).
I know other folks have used them. Can you run the hex shaft directly in the ball bearings without fear of point-loading the inner bearing race?
Unread 01-10-2008, 10:45
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Hex Shafts and Bearings
While it might be possible to do that for a while it is not a proper practice. Most teams turn down the ends of the hex shaft on a lathe so that it is round. There is also one other method which involves broaching bushings to the size of your hex and then putting that on the shaft to go in the bearing
Mentor 2415
Unread 01-10-2008, 10:56
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I have always seen them turned down to round which is pretty easy with a 3 jaw chuck on a lathe, and some patients. If you are turning steel, it may be better to use HSS rather than carbide, because carbide will sometimes chip.
That being said, the point loading probably isn't a big worry to the bearing, but soft hex stock may yield at those points and thus be sloppy similar to a shaft that is several thousandths too small.
If you are switching over to hex, you will also want to have a broach and press to make custom interfaces.
If you only have a 4 jaw chuck for your lathe, some options might be:
Buy a 3 jaw (this could be cost prohibitive depending on lathe.
Make a round insert and then broach a hex. Cross drill and add a set screw.
Use square stock instead of hex. (you will also need a square broach). This does not seem to get used in FIRST as much so expect replacement parts to be custom.
Unread 01-10-2008, 11:03
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Or if your lathe will take 5C collets, get a hex collet the right size.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 01-10-2008, 12:20
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
http://www.chiefdelphi.com/forums/sh...aft+ bushings
check out page 2 of this thread paul and aj have some suggestions on hex shafts, especially post #26 from aj if you are worried about the point loading
Unread 03-10-2008, 02:41
bmarick bmarick is offline
FRC #2374 (Crusader Bots)
bmarick is on a distinguished road
Question Re: Hex Shafts and Bearings
hey im wondering what are the advantages to this switch? i'm confused on why you would change other than the the key getting lost at the worst time. which is why i always make sure we get extras .
Unread 03-10-2008, 04:04
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
A hex is superior to a key in pretty much every respect. You nailed one reason. No keys to lose. Another reason is that it's a pain is keys often don't fit into keyways easily, or over time the key can seize the wheel to the shaft (or sprocket or whatever you've keyed to a shaft). Keying a sprocket also introduces a major stress riser on the hub. Every sprocket failure we have ever had (and I believe the same is true for 968) occurred on the keyway of the sprocket.
Hexes mean assembly is way faster. They just slide on and off way more easily than any keyed interface I have ever used. It also is better at transmitting torque, as you have a vastly larger surface area to deliver the same amount of torque-this eliminates the stress riser associated with keyways.
If you have the ability to use hex shafts and hex broached gears/sprockets/wheels, it's an absolute no brainer, in my opinion.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-10-2008, 08:12
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
I totally agree with Cory. One additional advantage is that the hex automatically centers the thing (gear, hub, sprocket) it is driving when torque is applied.
Andy B.
Unread 03-10-2008, 08:21
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
The method mentioned above is the cheapest and fastest way to pass a hex through a round bearing. Oversize your bearing id to accept a bronze bushing with suitable side wall. Then broach the bushing to use as a sleeve for carrying the hex.
You can also find something like this. Though I do not know of a source that stocks these.
Some notes about hex shaft from a former "hex only advocate." In applications where backlash and precision are a concern, say in an arm joint assembly, hex shafts can be less then desired. A broached hole is quite accurate, but hex stock has uncontrolled dimensions and may provide a loose fit.
Milling your own hex onto your shaft will allow you to control the fit precisely, but this requires more machining capability and diminishes the main 'ease of use' advantages.
For drivetrains, where lash is not a huge deal, hex is the way to go......
Also, precision ground keyed stock is readily available and keyway broaches are cheaper than hex broaches.
Good luck.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 03-10-2008, 14:20
some of that shot over my head, but that makes sense
Unread 03-10-2008, 15:31
Dick Linn's Avatar
no team (Synergy)
Hey, someone want to contact these folks and find out price/availability/sizes of their hex shaft adapters? Might be a cheap solution.
http://www.bnb-industries.com/Roller...%20Bearing.htm
See middle of page.
Stock Drive Products has round sleeves with a hex hole:
www.sdp-si.com/D790/PDF/D790C04023.pdf
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 03-10-2008, 16:21
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Small Parts sells hexagonal sleeves, but they aren't cheap.
Unread 03-10-2008, 20:49
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Does anyone know where to get a ball bearing with a hex in, like shown on aj's post. I was looking for a mcmaster number.
Thanks in advance.
R.C.
MadTown Robotics Team 1323
Unread 03-10-2008, 20:51
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Dick Linn View Post
... Stock Drive Products has round sleeves with a hex hole:
The Small Parts item appears to have the same properties as the SDP-SI item that Dick linked just above. The SDP-SI item is priced much lower.
AndyMark sells a very nice hex hub for $15 each.
Now if someone would offer hex shafts that are turned down to 0.4995 inch on one end...
Richard Wallace
since 2003
Unread 04-10-2008, 09:12
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Some sweet poly bearings, but no 1/2 or 3/8 hex sizes:
https://qbcbearings.com/BuyRFQ/BallB_Plastic_FC.htm#
Bearings and axel size Adama Technical Discussion 10 19-01-2007 14:15
keeping hex-shaped shafts in the couplings DaveG702 Motors 5 02-02-2003 21:03
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
Are bolts to hold wheels on, and bearings, considered "fasteners"? kmcclary Off-Season Events 3 22-10-2001 23:35
