#20
Re: New Control System How To
The real test on the control system will be when we start putting high current through these WAGO connectors. I have seen more failures with these things than not under high current. The little metal tab which contacts the wire (typically about 1/4 the wire size) has a tendancy to heat up and cool down losing its spring ability and thus losing contact. Expecially with constant movement and shock.
At our new Menards in Holland I have personally replaced about 40 of their wirenut versions which use the exact same concept, 6 of which had such a catastrophic failure that the fire department was called. -MIke |
| New Robot Control System! | Shinigami2057 | FIRST E-Mail Blast Archive | 135 | 23-09-2007 22:34 |
| New control system? | David55 | Rumor Mill | 2 | 29-12-2006 08:28 |
| New control system ... new forum. | Brandon Martus | Control System | 0 | 06-01-2004 15:05 |
| New Control System Photos | archiver | 2000 | 18 | 23-06-2002 22:13 |
| New Control System? | smokescreen | Rumor Mill | 4 | 07-03-2002 15:48 |
