Re: Best hand tool to use to cut sheet metal (aluminum diamond plate)?
A 4.5 inch angle grinder with a cutoff wheel works quite well. the cutoff wheels look just like grinding wheels but thinner.
All,
Thank you for all the great responses! I was mistaken when I made this original post at work today. I found it strange that there were so many posts saying how dangerous it was to do what I wanted to do with a simple hand tool, or advising something a little beefier when I knew what the plate looked like, & what (thicker aluminum material) we've cut on the team with other tools. I made a mistake with my measurement I originally stated since i tried to recall what it was while at work and not while the piece was in front of me. I just measured it, & the metal is only 1/8" thick (actually more like .130" - thicker across the treads of course since it is diamond plate). Does that change anyone's answers? Sorry for the call to repost advice , and thanks in advance to those who will repost now that I gave the correct info. ![]() Last edited by Elgin Clock : 02-10-2008 at 00:25. |
Good luck! |
| ALuminum jig plate - cheap surplus | Dick Linn | Technical Discussion | 0 | 19-12-2007 12:40 |
| Rules concerning manipulating circular diamond plate on a spider leg for stability | Drew | Rules/Strategy | 3 | 09-01-2007 14:51 |
| How do you tell whether your sensor is detecting a crate or the diamond plate? | Greg Ross | Technical Discussion | 4 | 13-01-2003 19:02 |
| Aluminum Plate | archiver | 2001 | 1 | 24-06-2002 00:03 |
| 1/4" Aluminum Plate | Brian_Lim | Rules/Strategy | 3 | 15-01-2002 18:32 |
