Go to Post Every thing is a hammer except for the screw driver which is a chisel. - BradL [more]
Unread 01-10-2008, 23:45
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: Best hand tool to use to cut sheet metal (aluminum diamond plate)?
A 4.5 inch angle grinder with a cutoff wheel works quite well. the cutoff wheels look just like grinding wheels but thinner.
2016 Central Illinois Winner. Curie Division finalist
Unread 02-10-2008, 00:20
Elgin Clock's Avatar
FRC #0237 (Black Magic)
All,
Thank you for all the great responses!
I was mistaken when I made this original post at work today.
I found it strange that there were so many posts saying how dangerous it was to do what I wanted to do with a simple hand tool, or advising something a little beefier when I knew what the plate looked like, & what (thicker aluminum material) we've cut on the team with other tools.
I made a mistake with my measurement I originally stated since i tried to recall what it was while at work and not while the piece was in front of me.
I just measured it, & the metal is only 1/8" thick (actually more like .130" - thicker across the treads of course since it is diamond plate).
Does that change anyone's answers?
Sorry for the call to repost advice , and thanks in advance to those who will repost now that I gave the correct info.
Unread 02-10-2008, 01:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Elgin Clock View Post
All,
Shear it. We have a piece of junk JET shear, and we can easily do 1/8" aluminum.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-10-2008, 01:31
FoleyEngineer's Avatar
FoleyEngineer FoleyEngineer is offline
AKA: John Crombe
FRC #0910 (Foley Freeze)
FoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond repute
I just measured it, & [b]the metal is only 1/8" thick (actually more like .130" - thicker across the treads of course since it is diamond plate).
No. In fact, it's even easier to cut 1/8" diamond plate with a jig saw.
Good luck!
2014 Buckeye Champions - thanks 846 & 639, Troy Champions - thanks 33 & 5193, Imagery, Entrepreneurship & Industrial Design Awards
2013 Kettering Champions - thanks 70 & 862, Three Imagery Awards
2012 Western Mich Finalist - thanks 1918 & 85
2011 Trav. City Web Site, Troy Xerox, Mich State Semi Finalist & Judges Awards
2010 Kettering Champion - thanks 67 & 70, Kettering Rockwell Innovation 2010 Troy Finalists - thanks 33 & 288, and Rockwell Innovation
2009 Kettering QF, Detroit Finalists Detroit Creativity Award, Troy Semi-Finalists Troy Creativity Award
2008 WMRI Finalists - thanks 1243 and 904, 2008 Kettering Champion - thanks 67, 1075 and 2619
2008 IRI Judges Award Winner, Great Lakes Finalists - thanks 66 & 217, Western Mich
2007 Curie Division Champions - thanks 330 & 1270
Unread 02-10-2008, 02:01
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Safest: Sawzall
Quickest: Plasma Cutter
Unsafest: Circular Saw
Most Impressive: Huge sheet metal shear
Least Plausible: Willing the material into severance by directing your thoughts
-q
p.s. Reccomended: Sawzall or Plasma torch.
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 02-10-2008, 02:05
AdamHeard's Avatar
Lead Mentor
Shear will give you the fastest, cleanest cut. I'm sure a lot of local places have one (more than just sheet metal shops), and if this is for robotics, would be willing to help out.
Unread 02-10-2008, 10:12
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yes, my answer changes to be like Adams.
Unread 02-10-2008, 11:09
Dick Linn's Avatar
no team (Synergy)
A shear would do it in a jiffy.
For reference, here is one brand of metal cutting saw blades (Morse Metal Devil):
http://www.mkmorse.com/
http://www.metaldevil.com/
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
ALuminum jig plate - cheap surplus Dick Linn Technical Discussion 0 19-12-2007 12:40
Rules concerning manipulating circular diamond plate on a spider leg for stability Drew Rules/Strategy 3 09-01-2007 14:51
How do you tell whether your sensor is detecting a crate or the diamond plate? Greg Ross Technical Discussion 4 13-01-2003 19:02
Aluminum Plate archiver 2001 1 24-06-2002 00:03
1/4" Aluminum Plate Brian_Lim Rules/Strategy 3 15-01-2002 18:32
