Go to Post oooo can i get bear hugged at monty madness...please big mike, please - Rohith Surampudi [more]
  #31   Spotlight this post!
Unread 01-10-2008, 02:39
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: drivetrain idea (comments please)
If you use 2x1 and at a 1/16" for the frame, make sure if the shaft is live put bearings in the frame. But if the wheel rotates on the shaft, put bushings in those spots where the shaft rests. If you leave the shaft by itself in the frame, over time it will eat away at the frame. I prefer to stay away from direct drive because you either have to hex or key your wheels.
R.C.
MadTown Robotics Team 1323
  #32   Spotlight this post!
Unread 01-10-2008, 10:51
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I feel like broaching your wheels and sprockets for hex shaft and using live axles is actually potentially more reliable. At least you dont have to worry about the bolts holding the sprockets to the wheels from loosening. Another thing they could do is have simple bearing blocks machined out of 1/4" thick aluminum to give something a bit more substantial for the bearings to sit in. Although I would agree that if they are using the kit wheels it makes more since to go with dead axle since you would then have to use a keyed hub of some sort.
Mentor 2415
  #33   Spotlight this post!
Unread 01-10-2008, 12:08
R.C.'s Avatar
Direct Drive is awesome, but a the drive he has set up will be fine and will work just as good. As long has he has aligned the sprockets up and the chain, he will be fine. Nice drivetrain and keep cadding.
R.C.
  #34   Spotlight this post!
Unread 02-10-2008, 18:46
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
I saw someone mention tracks in this thread a ways back, and they didn't provide much of a competitive advantage in this years game as it has in some, although were fine tuning and improving upon what we had.
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
  #35   Spotlight this post!
Unread 03-10-2008, 02:34
bmarick bmarick is offline
FRC #2374 (Crusader Bots)
bmarick is on a distinguished road
Cool Re: pic: drivetrain idea (comments please)
the one advantage to this idea i can see and have found out from discussing this with other is that you can add a second gear ratio to the spin. But i see no problem in your design other then i would think about not dropping the center wheel at all. keep up these ideas because they cause great discussions. I know I learned alot.
  #36   Spotlight this post!
Unread 03-10-2008, 09:45
AKA: Sean
Unless you want to not be able to turn well at all and potentially trip the breakers whenever you attempt to turn you have to lower the center wheel. We lowered it 1/8" last year with 6 kit wheels and it was perfect. No noticeable rocking but it could still turn perfectly. The only way to not lower the center wheel is to use omni wheels in the corner to allow slip while turning.
Mentor 2415
  #37   Spotlight this post!
Unread 03-10-2008, 12:04
Originally Posted by sdcantrell56 View Post
Unless you want to not be able to turn well at all and potentially trip the breakers whenever you attempt to turn you have to lower the center wheel. [...] The only way to not lower the center wheel is to use omni wheels in the corner to allow slip while turning.
Careful about blanket statements like that. Team 25 doesn't exactly drop their wheels (to my knowledge) and they still turn easily. I'm not sure exactly how they do it. It sure doesn't affect the rest of the robot, though. There may be one or two teams who use similar setups.
  #38   Spotlight this post!
Unread 03-10-2008, 14:12
oursystem did not need a drop but we used omni for comp. as long as you reverse the direction of one side to turn you should be fine. only you gent more friction thus lower speeds
  #39   Spotlight this post!
Unread 03-10-2008, 14:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I don't know of teams not named 25 who have been able to skid steer with a 6wd with no dropped center and no omnis. I'd say it's a pretty safe blanket statement.
2001-2004: Team 100
2006-Present: Team 254
  #40   Spotlight this post!
Unread 03-10-2008, 14:55
They've been telling other teams how they do it. Then again, not many have copied the design.
I'd also guess that many who try it for the first time (without asking advice here first, that is) quickly find out about the scrub and the "fun" associated with it, and change to an omni/drop configuration.
  #41   Spotlight this post!
Unread 04-10-2008, 16:05
AKA: Sean
I would say it is a very safe blanket statement. I was waiting for someone to chime in with team 25 as an example. Yes they do not drop the center wheel and they do have 6 traction wheels but as far as I know, they and maybe 103 who share a similar drivetrain are the only teams that don't drop the center wheel and have had success. I would say unless you are team 25, which no one is and very few are at there level, then I would recommend dropping the center wheel. You are not sacrificing any performance and in fact are improving your ability to turn and not trip the breakers.
Mentor 2415
  #42   Spotlight this post!
Unread 04-10-2008, 21:21
run the trap!!!
Team Role: Human Player
World Finalist 348 also used a team 25esque drivetrain. Having experienced their defense, I can attest to the speed and pushing power of this design. However, it did have a tendency to buck back and forth violently.
-Philip J. Fry
  #43   Spotlight this post!
Unread 05-10-2008, 01:00
R.C.'s Avatar
I was just watching a video of Team 25's match on the blue alliance and man they are spectacular.
R.C.
  #44   Spotlight this post!
Unread 05-10-2008, 01:21
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
As the conversation has drifted more towards true skid-steering drivetrains, I thought I'd point out my favorite: 1662 in 2006. Their drivetrain was very similar to the one posted at the beginning of this thread, but instead of six kit wheels, they had a four-wheeled drivetrain with 2"x8" IFI wheels. Talk about a robot that's hard to turn!
For those of us that aren't able to pull of such feats, six wheel drive with a dropped center works great. I would just recomend (as several others already have) that you add some bracing between the side rails of the chassis. I would prefer stickier wheels, too, but as it sits it looks like a solid base for your bot.
  #45   Spotlight this post!
Unread 05-10-2008, 13:23
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
definitly the cross brace or extra bracing is going to be needed. Otherwise it will bow over time. Can some one explain the degrees of rap to me. I'm still a little new to the drive train systems.
A sprocket is basically a circlular object (360 degrees). You want the chain to wrap around at least 1/3 of the sprocket (120 degrees). I personally suggest at least 150 degrees wrap with no more than 180 degrees.
The more wrap you have the more forgiving your drivetrain will be, but you trade off that forgiveness with added drag and friction. Going less than 120 degrees of wrap invites the chain to jump off of the sprocket.
___________________
- Tennyson, Ulysses
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
A new drivetrain Idea? Cody Carey General Forum 55 20-08-2006 12:48
Crazy drivetrain idea lukevanoort Technical Discussion 7 26-10-2005 21:19
Crazy Idea, looking for comments archiver 1999 74 23-06-2002 22:56
Another idea looking for comments archiver 1999 16 23-06-2002 22:01
