Hex Shafts and Bearings
We're potentially going to use hex drive shafts this year to get away from keys (that always seem to get lost at the worst times...).
I know other folks have used them. Can you run the hex shaft directly in the ball bearings without fear of point-loading the inner bearing race? |
Re: Hex Shafts and Bearings
While it might be possible to do that for a while it is not a proper practice. Most teams turn down the ends of the hex shaft on a lathe so that it is round. There is also one other method which involves broaching bushings to the size of your hex and then putting that on the shaft to go in the bearing
I have always seen them turned down to round which is pretty easy with a 3 jaw chuck on a lathe, and some patients. If you are turning steel, it may be better to use HSS rather than carbide, because carbide will sometimes chip.
That being said, the point loading probably isn't a big worry to the bearing, but soft hex stock may yield at those points and thus be sloppy similar to a shaft that is several thousandths too small. If you are switching over to hex, you will also want to have a broach and press to make custom interfaces. If you only have a 4 jaw chuck for your lathe, some options might be: Buy a 3 jaw (this could be cost prohibitive depending on lathe. Make a round insert and then broach a hex. Cross drill and add a set screw. Use square stock instead of hex. (you will also need a square broach). This does not seem to get used in FIRST as much so expect replacement parts to be custom. |
Or if your lathe will take 5C collets, get a hex collet the right size.
http://www.chiefdelphi.com/forums/sh...aft+ bushings
check out page 2 of this thread paul and aj have some suggestions on hex shafts, especially post #26 from aj if you are worried about the point loading |
hey im wondering what are the advantages to this switch? i'm confused on why you would change other than the the key getting lost at the worst time. which is why i always make sure we get extras
#7
Hexes mean assembly is way faster. They just slide on and off way more easily than any keyed interface I have ever used. It also is better at transmitting torque, as you have a vastly larger surface area to deliver the same amount of torque-this eliminates the stress riser associated with keyways. If you have the ability to use hex shafts and hex broached gears/sprockets/wheels, it's an absolute no brainer, in my opinion. |
#8
Andy B. |
#9
You can also find something like this. Though I do not know of a source that stocks these. Some notes about hex shaft from a former "hex only advocate." In applications where backlash and precision are a concern, say in an arm joint assembly, hex shafts can be less then desired. A broached hole is quite accurate, but hex stock has uncontrolled dimensions and may provide a loose fit. Milling your own hex onto your shaft will allow you to control the fit precisely, but this requires more machining capability and diminishes the main 'ease of use' advantages. For drivetrains, where lash is not a huge deal, hex is the way to go...... Also, precision ground keyed stock is readily available and keyway broaches are cheaper than hex broaches. Good luck. |
#10
some of that shot over my head, but that makes sense
#11
Hey, someone want to contact these folks and find out price/availability/sizes of their hex shaft adapters? Might be a cheap solution.
http://www.bnb-industries.com/Roller...%20Bearing.htm See middle of page. Stock Drive Products has round sleeves with a hex hole: www.sdp-si.com/D790/PDF/D790C04023.pdf Last edited by Dick Linn : 03-10-2008 at 16:16. |
#12
Small Parts sells hexagonal sleeves, but they aren't cheap.
#13
Does anyone know where to get a ball bearing with a hex in, like shown on aj's post. I was looking for a mcmaster number.
Thanks in advance. |
#14
AndyMark sells a very nice hex hub for $15 each. Now if someone would offer hex shafts that are turned down to 0.4995 inch on one end... ![]() |
#15
Some sweet poly bearings, but no 1/2 or 3/8 hex sizes:
https://qbcbearings.com/BuyRFQ/BallB_Plastic_FC.htm# |
| Bearings and axel size | Adama | Technical Discussion | 10 | 19-01-2007 14:15 |
| keeping hex-shaped shafts in the couplings | DaveG702 | Motors | 5 | 02-02-2003 21:03 |
| shafts, gears and wheels.... | archiver | 2001 | 13 | 24-06-2002 04:09 |
| A little tip about those drill transmissions and bearings | archiver | 2001 | 6 | 24-06-2002 00:22 |
| Are bolts to hold wheels on, and bearings, considered "fasteners"? | kmcclary | Off-Season Events | 3 | 22-10-2001 23:35 |
