Go to Post The best we can all do for our kids as parents, mentors and world citizens, is to model [Gracious Professionalism] always: not to win an award, but because it is the right thing to do. - chapman1 [more]
Unread 04-10-2008, 23:07
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Encoder Wiring for AndyMark Super Shifters
We bought AndyMark Super Shifters, and we wondering how to wire them the the RC. How do the four encoder wires fit with the three pin input on the RC? I've looked around an can't find any instructions for this.
Unread 04-10-2008, 23:23
Re: Encoder Wiring for AndyMark Super Shifters
From this datasheet, http://www.usdigital.com/assets/gene...atasheet_0.pdf, which I found through a link on the AM supershifter page, pin 1 is +5VDC power, pin 2 is A channel, pin 3 is Ground, pin 4 is B channel. The encoder will take 2 digital inputs to be able to detect direction.
Unread 05-10-2008, 09:44
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
Pin 1 (Orange Wire) +5VDC
Pin 2 (Blue Wire) A Channel
Pin 3 (Brown Wire) Ground
Pin 4 (Yellow Wire) B Channel
To wire the encoders to digital inputs, you will need 2 pwm cables for each side. Take one pwm cable and cut off the male end. Pull apart the three seperate wires (signal-A Channel, Ground, and 5V) by about 6 inches. Strip all the wires, including the ones hooked up to the encoder connector. Make sure to put heat shrink over all the wires before soldering the connections. Solder orange wire to red wire, solder blue wire to white wire, and solder the brown wire to the black wire. For the B Channel, you will use an entirely diffrent pwm cable. Take the 5V and Ground wires out of the pwm cable by prying on the plastic tabs on the female end. Cut the male end out and strip the white wire, finally, solder the B Channel wire, or pin 4 to the white wire and heat shrink all of the connections. Hope this helps.
Unread 05-10-2008, 12:59
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
As a warning, be very careful with these encoders. Since they're open frame and use the transmission bearings to keep the disc lined up in the encoder, they are very fragile.
If you have trouble with them being unreliable (breaking) you can try something like we used this year.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
AM Super Shifters Jeff 801 Technical Discussion 42 07-08-2008 23:42
AndyMark Super Shifter: Dos?? Pavan Dave Kit & Additional Hardware 18 23-10-2007 21:36
New AndyMark Super Shifter released... well, not just yet. RyanN Kit & Additional Hardware 4 16-08-2007 20:24
AndyMark - Super Shifter gearbox logo design contest Andy Baker General Forum 85 16-07-2007 21:09
New AndyMark Shifters! Gabe General Forum 32 18-01-2007 12:14
