Go to Post Don't forget the robot, the most important hardware there is!:p - artK [more]
Unread 04-10-2008, 11:21
Dick Linn's Avatar
no team (Synergy)
Re: Hex Shafts and Bearings
If any of you live near a community college that has a machining program, contact them and see if they will help with minor machining, such as rounding off the end of a hex shaft. Our local CC was delighted to help us put several of our #35 sprockets on a diet to save weight. They even gave me the mandrel they made in case we needed to do it again.
I've also had a local machine shop turn down some shafts for free.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 04-10-2008, 14:23
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Originally Posted by Andy Baker View Post
I totally agree with Cory. One additional advantage is that the hex automatically centers the thing (gear, hub, sprocket) it is driving when torque is applied.
Andy B.
Wouldn't it be cool if some small Indiana company would offer some bearing adapters and bearings for our applications?
Unread 04-10-2008, 15:51
Dick Linn's Avatar
no team (Synergy)
Take a piece of appropriately sized aluminum tubing or bushing. Taper the end of a scrap of hex stock slightly, lube it and pound it through the aluminum tube, thus forming a hex. Spin it and use a file to turn down the outside until it is round and fits the bearing of your choice. Of course, that means using a bearing of sufficiently large size to leave enough material at the points of your homemade custom-forged hex adapter so it stays together. You could probably get it done with a wood lathe or drill press.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 04-10-2008, 21:33
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I think everyone is making this more difficult than it needs to be. While I understand these solutions are probably geared towards teams who do not have a lathe, the best and easiest way is to use a lathe and turn down the ends.
I would guess that 90%+ of FRC teams could find a machine shop willing to do so in less than an hour of calling up shops. Just for reference, when we do this it takes no more than maybe 5-8 minutes to face a shaft to length, and turn both ends down to fit into a bearing. So you're talking about maybe an hour tops to do all of the shafts in your drivetrain. I really don't think you'd have a difficult time finding a shop to do an hour of work for you (especially since it's all manual and involves virtually zero setup time).
2001-2004: Team 100
2006-Present: Team 254
Unread 04-10-2008, 22:06
IndySam's Avatar
Originally Posted by Cory View Post
I thin everyone is making this more difficult than it needs to be. While I understand these solutions are probably geared towards teams who do not have a lathe, the best and easiest way is to use a lathe and turn down the ends.
Unless you want the bearings in the middle of the shaft.
Unread 04-10-2008, 23:38
I like your thinking. For example, it would be nice if the output sprockets in an AM Shifter could be hex broached instead of keyed or a smaller sized hex. To do that, the bearing in the gear that is between them and the dog would have to fit on a 1/2" hex shaft.
Unread 05-10-2008, 00:55
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
That is what i want, so i was thinking. What if you buy a bearing that has a 1 inch bore. Like this from mcmaster.com 60355K19. Then cnc or make a 1 inch bushing with a hex in the middle of it. Press fit the bushing into the bearing and try as hard as possible to not mess up the bearing. This way the sprockets and the gears can all be hexed @ the same size.
Or
Take the 1/2 inch hex and mill it down to a 3/8th's. Leaving a 1/2 inch circle for the bearing in the middle. I'll try to put up a drawing to illustrate what I mean. Sorry for the vagueness.
R.C.
MadTown Robotics Team 1323
Unread 05-10-2008, 01:11
Cory's Avatar
AKA: Cory McBride
Or
On the first point, standard hex stock is not real precise. It's going to be a pretty loose fit between the broached bushing and the hex shaft.
If you're machining a hex into round stock, it's a moot point. You want to do what I think you're saying in your second point, which is what 968/254 have done the last two years
2001-2004: Team 100
Unread 05-10-2008, 01:15
R.C.'s Avatar
Cory,
On the first part, we were going to have a 5 axis cnc make it. At our nearby college they have one. We have not been able to get our bits yet. We are still looking for clamps. But how has the second option worked for you.
-RC
R.C.
Unread 05-10-2008, 01:30
Cory's Avatar
AKA: Cory McBride
Cory,
-RC
I'm a bit confused. I don't really see how a 5 axis mill helps you. All you're doing is turning a plug and broaching a hole through the center. This is a manual lathe or 2 axis cnc lathe operation.
As for the way we do it, it works perfectly. It's more machining, but our shafts already require a live tooled lathe due to the non standard hex size, so really it's just a few minutes more run time.
2001-2004: Team 100
Unread 05-10-2008, 04:30
R.C.'s Avatar
I meant we needed a 5 axis for the shafts to be made (This part is my first suggestion). The bit isn't long enough on our regular CNC. So we take it down there. Hope that clears it up a bit.
R.C.
Unread 05-10-2008, 06:00
Cory's Avatar
AKA: Cory McBride
A 5 axis machine, either mill or lathe, is overkill (in fact depending on the type, if it's a mill, you may not even be able to do it). You need a 4 axis mill or a 3 axis lathe.
2001-2004: Team 100
Unread 05-10-2008, 11:48
R.C.'s Avatar
We don't have a CNC lathe, I wish we did. But all we have is a 3 or 5 axis Mill.
R.C.
Bearings and axel size Adama Technical Discussion 10 19-01-2007 14:15
keeping hex-shaped shafts in the couplings DaveG702 Motors 5 02-02-2003 21:03
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
Are bolts to hold wheels on, and bearings, considered "fasteners"? kmcclary Off-Season Events 3 22-10-2001 23:35
