Go to Post Nothing says poor quality like a wrinkle in duct tape. - Matt C [more]
Go Back   Chief Delphi > Other > Math and Science > NASA Discussion
Unread 05-10-2008, 13:14
Best Available Data
FRC #1778 (Chill Out!)
Re: Why does the Shuttle have Solid Rocket Boosters?
Originally Posted by Don Rotolo View Post
The SRBs are compact, simple in operation and stable in handling.
Liquid boosters need complex engines and support systems (pumps, storage bottles, valves, etc.) and have to be filled with relatively volatile stuff shortly before launch. While you can get more thrust from a liquid booster, it is physically larger.
So the advantages of a SRB include reliability and simplicity of use. Disadvantage as you mentioned is lack of throttle control.
There are proposals to switch to liquid boosters, but highly doubtful this generation of shuttles will ever consider them.
If solid propellants are so reliable and simple, why aren't they used exclusively for the shuttle? They generate more thrust than the external tank, and from this discussion seem relatively safe too. I understand the reasoning about being able to turn them on and off, but the external tank falls away too, and the shuttle uses the Orbiter engines to change orbits, doesn't it?
I think that's why I find this so confusing is it seems very at odds with itself. Why would they use liquid fuels for launch (from the earth to LEO at any rate) if the SRBs work so well?
Why the rules have obvious problems Matthew2c4u Rules/Strategy 9 06-01-2008 20:09
Why does the gyro need the ADC? cprogrammer Programming 16 27-10-2006 01:29
How high does the camera have to be Muhnki Programming 3 05-02-2005 13:14
Sometimes it DOES take a rocket scientist archiver 1999 5 23-06-2002 23:02
Does Anyone Have the numbers? archiver 1999 4 23-06-2002 22:20
