If you search for holonomic drive, you can find a number of posts about it.
Arthur Dutra wrote this code (and posted it) to support a holononmic drive. One joystick stick moves forward/back and side-side (and diagonally) for translation motion. The other joystic moves left/right to rotate, both can be moved at the same time.
The platform consists of four omni wheels mounted at 180 degrees from the next corner (ie two go "forward / backwards" two go "left / right"
Code is for the WPILibrary, so it should work fine with EasyC.
Let us know how you make out.
#include "API.h"
void main ( void )
int LF; // Left Front
int RF; // Right Front
int LR; // Left Rear
int RR; // Right Rear
int leftx;
int lefty;
int rightx;
int spin;
while ( 1 )
// Get Data
leftx = GetRxInput ( 1 , 4 ) ; // Left Joystick, X Axis
lefty = GetRxInput ( 1 , 3 ) ; // Left Joystick, Y Axis
rightx = GetRxInput ( 1 , 1 ) ; // Right Joystick, X Axis
// Half the input signal (so code does not overflow past 255)
leftx = leftx / 2 ;
lefty = lefty / 2 ;
spin = rightx / 2 ;
// Drive Code Algorithim
LF = RR = lefty - leftx + 127 ;
RF = LR = 255 - lefty - leftx ;
RR = 255 - RR ; // Reverse Direction of RR motor
LR = 255 - LR ; // Reverse Direction of LR motor
// Spin Code Algorithim
RF = RF - spin + 63 ;
RR = RR - spin + 63 ;
LF = LF - spin + 63 ;
LR = LR - spin + 63 ;
// Code overflow prevention
if ( LF < 0 )
LF = 0 ;
else if ( LF > 255 )
LF = 255 ;
if ( RF < 0 )
RF = 0 ;
else if ( RF > 255 )
RF = 255 ;
if ( RR < 0 )
RR = 0 ;
else if ( RR > 255 )
RR = 255 ;
if ( LR < 0 )
LR = 0 ;
else if ( LR > 255 )
LR = 255 ;
// Set Motors
SetMotor ( 1 , RF ) ;
SetMotor ( 2 , LF ) ;
SetMotor ( 3 , LR ) ;
SetMotor ( 4 , RR ) ;
