Go to Post Above all, have fun and, if you need help, ask for it... Your inspectors will be glad to help or try to arrange for another team to help you. This should not be a traumatic experience! - Mike Betts [more]
Unread 08-10-2008, 12:32
Re: Team 39, 2008 LabVIEW Beta Code
Originally Posted by Kevin Sevcik View Post
1. I assume the pink wires in and out of the various modules (DigMd, AnlgMd) are carrying module configuration info. Are the shift registers you have on these module configuration lines actually necessary? Could they instead just be simple tunnels, as with the Joystick in your main loop?
That is one point on which several beta teams are confused. It really depends on whether the references carry state information (best I can tell, some do and some don't). There have been a lot of ideas thrown around on how to improve things, both through examples and added documentation.
2. Is 25 Hz just a random loop timing decision on your part, or is it the recommended max loop rate?
It is the rate at which the driver station sends data. That should be raised soon. I have not seen any recommendations as to a maximum.
3. The Victor/PWM modules seem to have some sort of deadband and transform setup. Does that configuration happen in a separate module?
There are 4 PWM type VI Libraries, a raw PWM, a Victor, a Jaguar, and a servo. The Victor, Jaguar, and Servo have different types of deadband and scaling control. You can use the raw PWM, if you want to implement your own methods for scaling and or deadband elimination.
For example, The deadband control for Victor is a boolean value, whether to scale the inputs to eliminate the victor deadzone and center on 127 (rather then 132) or not.
Posting LabView Code Easily? Greg Marra NI LabVIEW 17 25-11-2009 16:49
LabView FRC Toolkit code level issue KHall National Instruments LabVIEW and Data Acquisition 2 11-06-2008 10:40
[TBA] Match Archives 2008 (beta) Greg Marra The Blue Alliance 16 07-10-2007 14:39
Configuring Labview code to easyC team877 LabView and Data Acquisition 6 16-01-2007 09:21
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
