Re: E- Stop and The New FRC Control System
This does mean, however, that a team always has to have their switch on hand in order to enable the robot. |
An additional good safety system, if not necessarily for FRC robots, is the deadman switch. It's (usually) a 3-position switch that's only closed when squeezed half way. Released or gripped tightly, the switch is open and the robot should cease operation. The reasoning being that humans are likely to release something OR grip something tightly in a panic situation, but likely won't maintain a calm, light grip on something. Probably annoying to have an over excited driver kill your robot in the middle of a match with a death-grip.... but it might make a good training tool for encouraging the drivers to stay calm in practices. ![]() |
Seems to me like a switch that requires a light grip would be more of a pain in the neck than a safety feature. If you aren't trained to "click the button if something bad happens" and are incredibly likely to panic in the event of an emergency, you probably shouldn't be the one holding the e-stop switch.
I do like the fact the new behavior of the e-stop this year (NC). I've nearly been run over a couple of times due to the lack of an e-stop button. |
Well, deadman switches aren't just a backup for E-Stops. They're often there specifically as enable switches for manual controls. So you have to active the switch before you can start moving around a large and dangerous robot, and you can't easily accidentally operate it.
Plus, how much use is an E-Stop button going to be if the machine you're operating electrocutes you, knocks you unconscious, or bores you to sleep? All of these situations leave the E-Stop button unpressed and the machine merrily humming away. Deadman switches don't just protect against machine operating dangers, they also protect against operator inattention. |
| OpenCV and New Control System | manderson5192 | Programming | 11 | 04-01-2009 16:11 |
| FRC control system to show up as default in the portal | BornaE | General Forum | 0 | 25-09-2008 17:00 |
| new FRC control system? | Jwxie | Programming | 2 | 30-06-2008 20:34 |
| New Innovation FIRST control system and the dashboard | archiver | 2000 | 0 | 23-06-2002 22:15 |
| UNFAIR ADVANTAGE for CDI and new control system | archiver | 2000 | 6 | 23-06-2002 22:13 |
