Re: Bacon Academy Website
Visual Response
Pros: -Quick to load -Easy to use design -Clean and compact Advice: -Optimize the images to make them smaller in data size -Make the background a color other than white -Keep all design images (menu buttons, title images, etc) included in a background image. This way, when people select your entire site, only the text is highlighted. It's also neater markup. -Add Javascript effects to those links. Technical Response Pros: -Well labled, well indented -Essentially valid markup -Consistent style -Fairly good use of CSS to replace attributes Advice: - Use DIVs instead of tables to align content in your page. You can probably shave half the HTML from your site with this method - Move the script at the beginning of the page inside the HEAD section - Remotely link all scripts, if possible - Set it up to validate with the W3 checker (XHTML strict, preferably) - The date can easily be generated with ASP, so don't use Javascript Content Response Pros: -Easy to get basic information -Nice calendar design with popup info -Good job including basic team info on front page Advice: -Set up the forums -Make thumbnails for the image gallery -Add more info about individual players -Add more information about the team in general... a history, quotes, involvement in the community, etc Overall, if I were to judge this site competitively today, I would give it a 6/10. Considering that your not finished, this is actually fairly high (it's probably better now than most of the finished sites will be). Keep up the good work! |
| pic: Team 1902- Exploding Bacon 2008 Robot | Matt_Kaplan1902 | Extra Discussion | 33 | 11-02-2008 13:32 |
| pic: Exploding Bacon lego version | dbell | Extra Discussion | 12 | 01-05-2007 15:28 |
| Video Autonomous 1902 Exploding Bacon | Doug Leppard | General Forum | 16 | 27-02-2007 12:44 |
| paper: Exploding Bacon Chairmans | wendymom | Extra Discussion | 4 | 24-02-2007 13:22 |
| Vex contest from Exploding Bacon | wendymom | General Forum | 54 | 12-10-2006 22:06 |
