Go to Post This is probably one of the most important robots in FRC history and it never even was in an official event. - gyroscopeRaptor [more]
  #31   Spotlight this post!
Unread 25-09-2008, 17:57
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: First: 2008 Batteries are D-Y-I-N-G.
http://www.batteryuniversity.com/index.htm
very cool battery link.
  #32   Spotlight this post!
Unread 08-10-2008, 23:29
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
I would like to know what people are using to test their batteries and what standard they are using. Thank you.
Seth
  #33   Spotlight this post!
Unread 08-10-2008, 23:36
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
We had quite a few batteries die on us. We think it is because, during a demo, we drained them very low, like 5 volts on the OI low, causing the plates inside to corrode.
When "charged," the voltmeter says the battery's voltage is fine, but it cannot deliver enough current to run the robot. So as advice to all teams, NEVER discharge your battery to the point where, on the OI, it reads a very low voltage.
We wasted a few practice rounds at SVR last year because we were putting batteries that said 13+ volts on the voltmeter on them, but couldn't deliver current, so the robot couldn't move.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
  #34   Spotlight this post!
Unread 09-10-2008, 01:15
Seth,
We use the CBA II battery analyzer from West Mountain Radio. If you look earlier in this thread you will see actual curves from actual batteries.
Pikat,
I know that this will sound weird but teams who draw lot's of current during driving can easily draw the battery below 5 volts during those high current demands. The internal resistance of the battery is 11 mOhm so a 400 amp draw will drop the terminal voltage of a fresh battery by 4.4 volts. At the end of a match where the internal resistance rises, this resistance will cause a further voltage drop.
Everyone,
A voltmeter only tells you the "open circuit" voltage of the battery. A voltmeter does not draw current (not enough to change the reading) to cause a drop across the internal resistance of the battery and therefore is not a good indicator of battery health. A current tester will show what the battery is capable of delivering under a load. The CBA II will draw up to 7.5 amps and West Mountain makes a high current device as well. However, one must know what the data tells them. It is possible that the battery has reduced capacity in that it can only deliver current for a fraction of the time a good battery can, the battery cannot supply current at full voltage or a combination of the two. A battery that cannot supply current for a normal length of time has some internal condition that prevents correct operation. I know that this is a foreign concept, but the data sheet specifies these batteries to have a 400 charge/discharge cycle life. It is very easy for a team who only keeps a few batteries in their inventory to run 400 cycles in a season between practice,demos and events. Charge when the battery is hot, store at temperatures near or below freezing, or deplete a battery in just one two minute match will shorten that 400 cycle life by half or more.
  #35   Spotlight this post!
Unread 09-10-2008, 01:21
The Blue Alliance
Pikat,
Good point. I was referring to the fact that we were running our robots for hours at a time (not high load, just driving it around) without changing the battery. In other words, these lead-acid batteries don't like to be fully discharged.
Eugene Fang
  #36   Spotlight this post!
Unread 09-10-2008, 01:54
AKA: Dr. Brooks
no team (WRRF)
Seth
We load our batteries at 20 amps, and measure the time that
it takes to drop to 11 volts. We don't go all the way to 10.5 volts
because deep discharge is not good for the battery. We load
using a constant current device, but you can do a reasonable
job with high power resistors from digikey. We qualify our
batteries every season, tracking their performance year to year.
You can make yourself a tester with high power resistors,
a fan to keep them cool, and a spike. It is not a constant
current load, but it is close enough. You can measure the
voltage using a voltage divider hooked to an analog input.
The old EDU RC is very good for this. It is a great project
for your robot team to do, producing a load tester that will
get used every year.
Eugene
  #37   Spotlight this post!
Unread 10-10-2008, 14:55
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Teams should not compare MK batteries with previous years as they are different in construction. There is a difference, between gell cell batteries and the MK AGM batteries. It would appear that the MK batteries are a little more sensitive to shock and mishandling.
I would like to disagree with the bold in this statement. It is taken a touch out of context, but I will explain why. In the world of engineering, we buy parts to meet a specification...
Semi-Tangent:I happen to work in the military engineering world where the standards are extremely high - could you imagine dropping a cellphone off a 3 story building and have it work when you pick it up? Our radios are required to do this. Could you imagine leaving your car stereo underwater for 3 days, expect to pull it out, let it dry for an hour and have it work? One of our radios DID that during Katrina & saved lives... Could you imagine exposing your robot to -30degreesF or +120degreesF and expect the electronics to still work? Our radios have to. They have to and we design them to meet that. We cant use parts in them that dont allow us to meet our -30degree requirement. We cant use a battery that will only last in our product for an hour, or our soldiers wouldnt be able to carry enough batteries to last a mission.
Yes, these are extreme examples, so whats my point? My point is that FIRST is FORCING us to use this vendor and this battery, they have lain the specifications for us. We dont really know why MK... did they get a better discount/donation or a sponsorship donation from MK? did the old battery vendor not want to donate anymore? did they think that these batteries were actually better? Who knows. But the reality is that these batteries ARENT as good as the old ones, and teams SHOULD be comparing them. If there is something better out there, that meets the specification of a FIRST event better, we should be allowed to use it. Teams are right to raise an eyebrow because they are spending a lot of money on batteries. Some try to keep up to 10 at a time alive, and thats a BIG expense. At bare minimum you need 4 if you are going to end up in the finals (unless you beg & borrow), and having to buy new ones put us all on edge. Now it appears that there is evidence that they arent as robust and dont hold up to the riggors of a FIRST team's usage as well as the old ones. So maybe we/they should revisit the options...
My point being that Cellphone & Radio designers alike, we all design/engineer FOR our users. We are using motocycle batteries... they are not designed to be taken in and out, dropped, handled incorrectly, charged and discharged over and over again... so if we are using something NOT for its intended use, we need to find the part that most closely matches our specifications and will last the longest so teams dont have to take on that expense over and over again.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
  #38   Spotlight this post!
Unread 06-02-2009, 00:05
BlackBird11891's Avatar
BlackBird11891 BlackBird11891 is offline
We Rise Above Our Challenges
AKA: Chad Krivanec
FRC #1927 (Team Tempest)
BlackBird11891 is on a distinguished road
so were all in the shop the other day with the batteries on the chargers i leaned back on the table and burned my arm (not really bad, but it left a mark) i quickly turned around to notice that one whole cell of the battery had bulged out and the battery had gotten up to 165 degrees and was leaking out the top
For all those who are thinking this the battery was fully dead when we put it on and hadn't been on the charger for 2 long before this happened
  #39   Spotlight this post!
Unread 06-02-2009, 00:20
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
It sounds like the charger is messed up... I bet Thomas broke it. Tell him Ryan Nazaretian sent you.
Just remember to dispose of the battery properly, and also keep a close eye on that charger. Is it one of the new smart chargers, or one of the older chargers?
I'm not too fond of 'Smart' chargers after one almost burnt down my work shop. Mine had an automatic trickle charge cycle that was meant to keep on a battery. Unfortunately, it failed with a deep cycle marine battery and burnt through the large charging cable (designed to carry 70AMPS). I was very fortunate that it was lying on the concrete instead of on top of my workbench.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
  #40   Spotlight this post!
Unread 06-02-2009, 02:06
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
We have also had a problem with the newer batteries. I have been in FIRST since 2002 and have had TWO Exide batteries go bad,(not including the oldest ones which have been retired when they lost the ability to hold a good charge) and to date We have had FOUR MK Batteries go bad on us. Just the other day I had one start to heat up and leak out of the top while charging. We order 10 every year and over the years we have a large stock of Exide batteries that still work. I understand that FIRST is probably getting them discounted and all but if the batteries are not holding up as well as the old ones.... Maybe one solution would be to still supply and offer MK batteries, but lift the restriction of using other batteries so those of us that want to pay a little more for batteries that last longer can do so. I do not think that the MK batteries are a bad product, but I do think we are using these batteries in a way they are not designed to hold up to as well as the batteries of the past have proven to.
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
  #41   Spotlight this post!
Unread 06-02-2009, 10:17
Racer26 Racer26 is offline
My team has never really had many batteries to our name, but from my experience, the exides DID hold up better.
  #42   Spotlight this post!
Unread 06-02-2009, 12:50
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
Reading through all these posts, Al and Don make some excellent points here. I want to add a little information for those that don’t go to the battery university website or want to spend hours researching battery characteristics.
If you discharge a lead acid battery too far, you hurt the battery and its amp hour capacity will be reduced.
Typical discharge to levels for batteries, or don’t go below this charge level.
Automotive batteries 80%
Marine batteries 50%
Deep cycle batteries 20%
Automotive batteries should not be discharged below an 80% charge level or you’ll hurt the battery. There is only 20% of the charge that is usable but the automotive battery will deliver more amps for the same physical size when compared to Marine or Deep cycle battery. In an automotive application the battery is discharge a small amount very shortly starting the engine and then is recharged by the alternator.
The FIRST battery seems to fall into the Marine category as the cycle life is greatly reduce if the charge drops below 50%.The information below is from the MK Battery website.
Life expectancy:
Cycle Use: 100% depth of discharge 250 cycles
80% depth of discharge 350 cycles
50% depth of discharge 550 cycles
What this means is that if you continually run your batteries down to low charge levels, you WILL significantly reduce the capacity of the battery.
On a side note, I don't like the battery charger FIRST supplies but they are better than the older non-smart chargers. I've seen these not sense properly and over charge batteries. This was probably due to a defective battery. I prefer the Black and Decker (used to be Vector) Smart Chargers. They use a three stage charging technology that helps extend battery life. I've given away or thrown away all my old battery charges for these new chargers, they are that much better.
FYI Some AGM batteries have platinum on the glass mat. This helps as a catalyst to recombine the oxygen and hydrogen bubbles if the battery is over charged or charged at too high of a current.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
**FIRST EMAIL**/Call for Proposals - 2008 FIRST Robotics Conference Mark McLeod FIRST E-Mail Blast Archive 6 21-12-2007 09:35
**FIRST EMAIL**/2008 FIRST Scholarships Available Mark McLeod FIRST E-Mail Blast Archive 1 08-11-2007 12:00
Where did first get the Edu Batteries hedgehogger General Forum 7 28-02-2004 01:09
What are some things that you associate with first or the FIRST regionals? A. Snodgrass Chit-Chat 12 24-02-2003 02:13
