Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
Unread 09-10-2008, 00:10
Pat Major's Avatar
Pat Major Pat Major is offline
#0494 (The Martians)
Pat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond repute
pic: Wind tunnel
Unread 09-10-2008, 00:13
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: pic: Wind tunnel
Is there any protection from foreign object (test items) from being sucked into the blades?
What kind of wind speeds can that tunnel produce?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 09-10-2008, 01:22
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
It'd be my guess that that fan blows air, not sucks it, thus no problem with FOD.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 09-10-2008, 03:08
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Where is this wind tunnel located?
I interned at the NASA Ames Wind Tunnel, which had 6, 40 foot diameter fans powering the tunnel. Depending on which test sections were being used, it either sucked air from the test section, blew air into the test section, or both, via cycling the air.
My guess is, depending on the test section size and fan speed, this wind tunnel can pull about 100 knots if it is the only fan drive. If there are more fans that speed will obviously increase. Cool field trip.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 09-10-2008, 03:19
REVving up for a new season
FRC #2848 (All-sparks)
Based on the team location I would say it is a fair assumption to assume this is at an automotive R&D facility.
Did they let you stand in the tunnel with some of the lower wind speeds? I once did that at university of maryland and it was an experience I will never forget.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 09-10-2008, 07:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Notice the blur of the fan blades?
GitHub
Unread 09-10-2008, 08:19
Pat Major's Avatar
The wind tunnel is at the Chrysler Technology Center in Auburn Hills Mi. Interesting story we were told: During the initial installation of the tunnel they could not get the scales that the car’s tires sit on to stabilize as they were trying to calibrate them. They resolved the problem by turning off the heating and cooling system to the room, they found that the air flow and change in pressure was the reason the scales would not stabilize. That was not the only issue; they also found they were picking up the vibrations from semi trucks as they were traveling the roads around the Tech Center. Accuracy…..quality…..they don’t mess around. The tour was very impressive for students and adults. We did not stand in the tunnel while it was in operation. We did walk the whole circuit and test the unbelievable acoustics
A river is powerful because many drops of water have learned the secret of collaboration.
Unread 09-10-2008, 10:55
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
All i have to say is that would be an amazing experience. SWEET
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 09-10-2008, 14:57
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
I would love to see the motor powering it and see it in action!!! (off to youtube to see if anyone posted a video )
I win! XD
Unread 09-10-2008, 15:10
GaryVoshol's Avatar
Cogito ergo arbitro
YouTube? Pat and Co are lucky to have even a still photo from this secure location.
(since 2004)
Unread 09-10-2008, 18:05
DonRotolo's Avatar
Back to humble
FRC #0832
No way anyone would be allowed to stand there if the fan was moving. No way no how.
OK, maybe in a James Bond movie, where you wanted to slice up the villain...
Unread 09-10-2008, 20:07
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
They normally let you spin the blade by hand to get an idea of the inertia and how good the bearings are. It might still be moving from that.
Unread 09-10-2008, 22:57
Onward through the fog.
That will be an experience not easily forgotten. Very cool!
~ Helen Keller
(1880-1968)
Unread 09-10-2008, 22:58
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I would love to see one of these bad boys in action.
R.C.
MadTown Robotics Team 1323
Unread 10-10-2008, 13:09
carla_rose's Avatar
carla_rose carla_rose is offline
People love my rhinstoned glasses
AKA: Carla*
FRC #0033 (Killer Bees)
carla_rose is a jewel in the roughcarla_rose is a jewel in the roughcarla_rose is a jewel in the rough
Send a message via AIM to carla_rose
We (The Killer Bees) have been on that tour before. That wind tunnel is so cool. I'm glad you guys enjoyed it too.
pic: Virginia Tech wind third in DARPA falconmaster Extra Discussion 4 07-11-2007 17:16
Wind Tunnel Wayne Doenges General Forum 48 21-01-2005 19:22
pic: 237 on the road with Second Wind Dreams CD47-Bot Extra Discussion 6 25-05-2004 01:45
