Go to Post Regardless on how you feel about any team--respect should be paramount. - MeGuttieri [more]
  #46   Spotlight this post!
Unread 08-10-2008, 21:36
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: pic: Spotted at IRI: New AM wheel (2)
Looks nice, I hope they will work just as well as the IFI high traction, which i really liked
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
  #47   Spotlight this post!
Unread 08-10-2008, 22:22
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Originally Posted by DarkFlame145 View Post
Bacon used a pair at Mission Mayhem and the tread kept falling out (couldn't cut the tread 100% right) and the lip that holds the tread in broke in 2 places on one side.
This is the first feedback we have heard. Can you provide more details? (pictures, how it happened, etc.)
Andy B.
  #48   Spotlight this post!
Unread 09-10-2008, 00:19
AdamHeard's Avatar
Lead Mentor
Originally Posted by Vikesrock View Post
Make a mark across the tread and wheel with a Sharpie? This is obviously not the most precise of methods as it will not be able to determine how much slipping occurs if it is greater than 360 degrees, but it would be a start at least.
EDIT: I just realized that this question may not be asking how to actually perform the test but rather if someone has or could perform the test. If it is the latter, ignore my comment.
Terribly worded on my part....
What I meant is can someone who has these wheels perform such a test.
  #49   Spotlight this post!
Unread 09-10-2008, 00:38
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We will put these wheels to the test Saturday morning but having these wheels in my hand I can tell you there is no way the tread will spin on the wheel. The tread is gripped tightly on the sides.
If a failure is going to happen it will be the tread coming off not spinning.
We have one tread cut just a couple mm's short and my guess is that that wheel will more than likely fail. The others that have no gaps between the ends seam very secure.
We will see.
  #50   Spotlight this post!
Unread 09-10-2008, 00:45
AdamHeard's Avatar
Lead Mentor
We will see.
I hope they don't fail as well, but there could be a couple hundred pounds of force (depending on gearing, wheel diameter and tread CoF) trying to get them to slip.
  #51   Spotlight this post!
Unread 09-10-2008, 21:44
A very nice typo-induced pun. I like it.
  #52   Spotlight this post!
Unread 10-12-2008, 17:30
Bob Steele's Avatar
AKA: Bob Steele
We were using this on our prototype and had slippage of the tread with the wheel. We were pushing very hard....low gear on a special transmission with two cims through a DeWalt transmission and running in the lowest gear.
The tread was wedged only and not riveted.
We were testing this on actual game carpet...looking at static friction and also pushing objects around the field.
this is a six wheel drive train with Kit wheels in the four outer positions and the plaction wheels on the direct driven motors in the middle. (West Coast drive train..)
The tread pulled up (sort of "bubbled" up...) at the point where it comes together ... we are using AM Wedgetop tread...
We are continuing to test.... and we just ordered 4 more plaction wheels to replace the kit wheels on the corners...
thanks
R
  #53   Spotlight this post!
Unread 15-12-2008, 12:59
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
222 ran these wheels through three competitions and two sets of tread. After our first hybrid of trying to push the wall with the plaction wheels we decided to rivet the tread on. Since riveting we had nothing but good luck! Kudos to Andy and Mark for these wheels!
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
  #54   Spotlight this post!
Unread 15-12-2008, 16:35
IndySam's Avatar
We had the same trouble in testing. We just used a little epoxy on the ends of the tread and had zero trouble at the CAGE match.
Unless the GDC throws us a curve ball we will be using these wheels this season.
pic: Spotted in my new Make:... Billfred Extra Discussion 10 27-03-2008 15:19
pic: New wheel CAD CraigHickman Extra Discussion 9 02-01-2008 20:29
pic: New wheel CAD CraigHickman Extra Discussion 4 08-09-2007 01:29
pic: my new wheel design hockeystud91 Extra Discussion 9 20-02-2007 19:18
Segway spotted @ Loudon New Hampshire mtaman02 Dean Kamen's Inventions 6 17-09-2002 17:37
