Go to Post you are going to gear that down right? Otherwise your robot will take about 10 minutes to reach its top speed of mach 2.6. - M. Hicken [more]
Unread 10-10-2008, 11:19
Yoel2630's Avatar
Yoel2630 Yoel2630 is offline
FRC #2630 (Thunder Bolts)
Yoel2630 is a jewel in the roughYoel2630 is a jewel in the roughYoel2630 is a jewel in the rough
Send a message via MSN to Yoel2630
(help)battery chargers
We had a problem with our chargers and now they don't work (not very clear what happend)
Anyways the reason I came here is because we want to buy a new charger and were told that there are a few options and some better then others.
So here some questions to direct you:
What are my options?
What kind of requirements do FIRST battery chargers need?
What do you use? and if for some special reason please specify why
Where can I get a charger?
How much should a charger cost?
(you don't have to answer all the questions if you don't know)
Thank you for helping
Yoel and team 2630
Unread 10-10-2008, 12:14
Re: (help)battery chargers
According to last year's rules, you have to use a 6-amp rated automatic charger. Note that the rules may change for 2009. Typically, FIRST includes a charger in the kit of parts, but those are not necessarily the only legal chargers.
Unread 10-10-2008, 17:22
DonRotolo's Avatar
Back to humble
FRC #0832
You need to decide if you want a competition-legal charger or something to just charge batteries. Please note that the competition-legal chargers are specified so that you don't damage the batteries by charging too fast, so it does make sense to heed their advice.
That being said, only the 2009 rules will tell us what is legal. It is a reasonable bet that a 6 ampere (max) fully-automatic charger would be good.
We use several chargers, some identical to the Kit chargers, some almost so. The recent kit chargers have nice lights and stuff, but the old chargers seem to be more resistant to user error.
A charger can be had at automotive and marine stores, including sears, JC Whitney (online) and perhaps large wall-o-china-mart stores.
A charger like that might cost about $50, more or less.
Unread 11-10-2008, 15:20
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Yoel, I searched around a little and found these:
http://www.harborfreight.com/cpi/cta...emnumber=45005
http://www.harborfreight.com/cpi/cta...emnumber=95533
http://www.harborfreight.com/cpi/cta...emnumber=94088
Can someone comment on these? are these just junk?
(But Harbor Freight only ships to the US.)
Maybe you could talk to Avi and see if he's in the US anytime soon.
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 11-10-2008, 20:12
DonRotolo's Avatar
Back to humble
FRC #0832
Any of those would be fine, although the middle one is limited to 2 Amps. They are Harbor Freight quality, which is OK if you understand what you are getting. Surely ones similar are available throughout the world, ya just gotta look.
Unread 12-10-2008, 08:26
Yoel2630's Avatar
Thank you guys
From what I understood car battery chargers and model airplane and model helicopter battery chargers seem ok.
They are available in Israel but the cost is much higher than in the USA.
Unread 12-10-2008, 20:02
Yoel,
There is at least one or two other threads that discussed chargers. I think I listed the charger we use. It is a 5 battery charger @5 amps each port and available from McMaster Carr.
Unread 13-10-2008, 00:07
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Picked up our first Battery Load Tester today. How we got by 8 years without one is crazy. But after so many battery charging problems last year - I sure hope this helps sort out what is good from what is not. We used a battery mount that had it laying down through the three competitions last year, and I think the shock load on the plates inside resulted in cracking so that we thought they were good but under load they just could keep up the voltage and cost us two matches in Atlanta.
So for teams... Go to your local Napa Auto parts and get a Battery Load Tester for about $50!!
Unread 14-10-2008, 18:19
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Hi Al,
Couldn't find that post, or the charger on McMaster.... would you mind re posting the model?
Thanks!
-Leav
-Paraphrasing JFK
Unread 14-10-2008, 19:43
Originally Posted by Leav View Post
Hi Al,
Thanks!
-Leav
Leav,
I went looking on McMaster and Grainger and couldn't find it. I will ask one of the other mentors if he remembers and get back to you.
Unread 14-10-2008, 19:47
AdamHeard's Avatar
Lead Mentor
Does anyone know if a battery laying horizontally can damage the plates? I've heard it makes no difference.
Unread 14-10-2008, 19:49
Leav,
http://www.chiefdelphi.com/forums/sh...09&postcount=7
Unread 15-10-2008, 00:11
AKA: Dr. Brooks
no team (WRRF)
For a 5 way ganged 6 amp charger, see the LS1206 at
https://www.batteryweb.com/interacter_specs.cfm
And click on the ganged charger link. The company
gangs the guts of 5 of the chargers you select.
We have one of these with 5 LS1206 six amp chargers in it.
Charger performance has been excellent.
Eugene
Unread 15-10-2008, 01:43
Thanks Joe,
This one is also very similar...
http://test.autometer.com/productDet...D=14&isKi t=0
Note that the charge current is automatic at 5 amps max, well within the charge spec for the battery and the First rules up to and including 2008.
Unread 15-10-2008, 03:40
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
holy battery charger markup batman!
thanks guys!
but what's with the huge price jump from the single chargers to the mutiple chargers??
the single battery chargers I was looking at were about $30-$50 which turns out to be $300 max for 6 batteries....
the cheapest I can find the Autometer buspro-600s is for $486.. 62% more than the singles!
anything I'm missing here? cause it seems that if you are willing to waste some space you are getting not only a better price, but also an option to spread them out (3 in the gym, 3 in the lab...)
Any insight would be greatly appreciated!
-Leav
-Paraphrasing JFK
Battery Chargers spadercool General Forum 1 04-02-2006 14:44
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
Battery chargers Perseus Electrical 9 19-03-2002 00:14
Battery Chargers Alan Ing Technical Discussion 20 09-03-2002 21:44
Battery Chargers pato General Forum 1 25-01-2002 00:46
