Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 12-10-2008, 12:22
ttldomination's Avatar
Sunny
Re: EasyC help - robot not following code!
Uh...
I'm not too sure why. If you could post some of the code here, that'd help debug your code. But if you're sure that there is not problem with the code
then I would try a different micro-controller.
1648: 2013-2014
5283: 2015
Help Autonomous code not working team550 Programming 5 14-01-2008 10:35
Programming help. EasyC Vex Robot. OneCoolDude Programming 2 02-12-2007 17:54
easyc demo code not working sniggel Programming 5 28-01-2007 16:40
Following the Green Light with robot. Wompas Programming 0 26-01-2007 17:34
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
