Go to Post I wonder if the FIRST Place Holiday Party partly consists of watching the site activity.... - Jessica Boucher [more]
Unread 12-10-2008, 14:03
tivomatic's Avatar
tivomatic tivomatic is offline
FRC #2262
tivomatic is an unknown quantity at this point
Re: Basic Labview Programming Questions
I am trying to write a Labview vi that takes a one dimensional numerical array, for example A= 5,4,3,2,1, and sorts the values in ascending order. We do not want to use the sort array operator since the whole purpose is to practice using labview. Although I can write this no problem using Basic, I am having trouble in Labview. . I have attached the vi.
Thanks.
Unread 12-10-2008, 15:21
Thanks.
I've attached a version that does what I think you want. The main thing you needed was a shift register (or feedback node) to take your changed array and feed it back so it could be operated on. The way you had it, each loop it was always operating on the original array. I must admit that this has been the thing I've messed up the most in LabVIEW.
You'll need another loop of some type to finish sorting. You can also use the array size VI for the input to the count terminal input of the for loop.
Unread 13-10-2008, 13:25
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Taking Mr. Ross' vi a bit further, I've modified it to swap array elements without overwriting the ith array element. Still needs another loop to control the number of passes through the array in order to propagate all of the changes each pass makes.
Unread 13-10-2008, 14:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Well that last VI is mostly correct, aside from either a second FOR loop to run it n-1 times, or a while loop that will stop if it didn't make any swaps in the last run of that inner FOR loop... But seeing Bubble Sort implemented in Labview seems very very wrong to me. There's a reason NI has VIs like this already made, after all.
Unread 13-10-2008, 14:47
I enthusiastically agree. Bubble Sort is a highly procedural algorithm, something which LabVIEW does only grudgingly. I wonder if a Partition Sort would more closely align with LabVIEW's data-flow nature.
But I think sorting is the kind of operation that should be implemented by people having deep knowledge of the runtime environment, and not used as an exercise in learning how to use a data-driven programming language.
Unread 13-10-2008, 18:29
If this is for learning purposes, then I see nothing wrong with it. In fact I've attached a few other implementations of sort, which will hopefully show some of the tricks and syntax with arrays as well as the relative performance.
[ATTACH]More sorting[/ATTACH]
If you decide to use a Bubble Sort on your robot, well then perhaps you'd like to build your own chain too.
Greg McKaskle
A few Labview questions Japper NI LabVIEW 14 09-09-2008 20:41
A few basic EasyC Pro questions Joe G. Programming 5 11-03-2008 21:18
Some Basic Questions... bglass Motors 5 02-07-2007 21:53
BASIC programming John Gutmann Programming 3 17-05-2005 12:15
Very Basic Programming Question kewlkid382 Chit-Chat 5 18-01-2003 11:11
