Re: EasyC help - robot not following code!
Are you using one of the provided compeition templates? If so, be sure there are no jumpers in interrupts five or six, as these will cause the robot to switch into either only autonomous or operator. As others have said, check to make sure your radio connection and power are good.
If you post your code, it will be much easier for everyone to help you, because looking in from the outside, it seems like a code error. Just to be sure, redownload the Vex master code. |
| Help Autonomous code not working | team550 | Programming | 5 | 14-01-2008 10:35 |
| Programming help. EasyC Vex Robot. | OneCoolDude | Programming | 2 | 02-12-2007 17:54 |
| easyc demo code not working | sniggel | Programming | 5 | 28-01-2007 16:40 |
| Following the Green Light with robot. | Wompas | Programming | 0 | 26-01-2007 17:34 |
| Kickoff easyC workshop integrated into EasyC help file | Dan Larochelle | Programming | 0 | 11-01-2006 06:12 |
