Go to Post If the world was like ChiefDelphi, people would be more eager to help out, offer advice and encourage each other to better things... not a bad world, that. - MissInformation [more]
Unread 14-10-2008, 15:03
cdanik cdanik is offline
cdanik
AKA: Chris
None #0255
cdanik is an unknown quantity at this point
Loose Chain
Any idea on a way to to tighten the chain? Our chain hangs at the bottom.
-Chris
Lamphere High School
Unread 14-10-2008, 15:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Loose Chain
It depends on how your robot is built. If it has slots to move the wheels or transmissions front/back, then you can loosen the bolts, slide them till the chain is tight, and tighten the bolts again. If there are tensioners, you can adjust them. If not, you might be able to add some. Or if the chain is too far worn to adjust it, you could remove a link and add a half link to make the chain shorter, then adjust it.
Pictures are very helpful for explaining your problems so others can see what you're trying to fix.
Unread 14-10-2008, 15:17
Re: Loose Chain
http://www.chiefdelphi.com/media/photos/31899
or
PVC/Delrin blocks in the middle
or
floating idler tensioners (AKA sprockets)
or
sliding the wheels out or the transmissions up and down
or
come up with something better if you don't like these suggestions.
Unread 14-10-2008, 20:07
Dick Linn's Avatar
no team (Synergy)
Re: Loose Chain
Pictures or sketches would be very helpful.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 16-10-2008, 09:04
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Loose Chain
If you upload some pictures, we may be able to help you more because different types of tensioners work better for different situations. There quite a few different tensioning systems that you could use.
-Vivek
"we don't build robots, we build people"
Loose Balls Rick TYler Rules/Strategy 23 18-01-2006 14:48
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
loose motors ivanslost Motors 11 18-02-2003 09:39
Strict or loose interpretation? Wetzel Rules/Strategy 2 08-05-2002 20:21
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
