Go to Post Bottom line: if it confuses my mom, it is bad for FIRST. - Joe Johnson [more]
Unread 14-10-2008, 21:11
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Vibrations during CNC
Does anyone have a simple way to reduce or eliminate the vibrations the CNC bit causes on a piece you're milling out? We're using C-channel for our side rails of our platform, and we're milling out holes for the wheel wells.
Near the end of the fourth run for each rectangle we cut out, the middle piece that's being cut out begins vibrating. It's not too rough, but it does cause noticable (yet tolerable) imperfections in the cut. Do we have to live with this (and file it down afterwards) or is there a way around it?
Thanks in advance.
GitHub
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
CNC Machines DEAL234 Technical Discussion 17 07-02-2007 16:30
CNC Options? Andrew Blair Technical Discussion 5 06-02-2006 18:12
Centroid CNC team222badbrad Technical Discussion 25 09-11-2005 20:36
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
