Re: FIRST Ranking Software
Thanks for the help everyone!
Scott, can I see a copy of it?
http://asp.shinraikon.com/duelvii/rank.aspx Here is the database in use.
Five table SQL join. Fun. (Four is all you need, actually, and it would be six if I only knew $eventid but not $season) This database is structured such that a table can contain data for multiple seasons and events, $eventid and $season are substituted for the database-specific event ID and year, respectively. It what I use for my scouting program to update team rankings.
The IF function is specific to MySQL, any other database will need to replace it with a standard IF/ELSE or CASE statment. Code:
SELECT t.teamnum, SUM(IF(a.score>o.score,1,0)) AS won, SUM(IF(a.score<o.score,1,0)) AS loss, SUM(IF(a.score=o.score,1,0)) AS tie, SUM(CASE WHEN a.score>o.score THEN 2 WHEN a.score=o.score THEN 1 WHEN a.score<o.score THEN 0 END) AS qualify, SUM(CASE WHEN a.score>=o.score THEN a.points WHEN a.score<o.score THEN o.score END)/SUM(1) AS ranking, SUM(1) AS matches FROM team t LEFT OUTER JOIN team_event u ON t.teamnum=u.teamnum, team_match m, alliance a, alliance o WHERE m.surrogate=0 AND m.disqualified=0 AND t.teamnum=m.teamnum AND a.matchid=m.matchid AND o.matchid=m.matchid AND a.alliance=m.alliance AND o.alliance!=m.alliance AND t.season=$season AND u.eventid=$eventid AND m.eventid=u.eventid AND a.eventid=u.eventid AND o.eventid=u.eventid GROUP BY t.teamnum |
| The FIRST Software Repository | roboticsguy1988 | Programming | 0 | 30-03-2008 23:08 |
| **FIRST EMAIL**/FIRST Announces PTC Collaboration Software Sponsorship! | Mark McLeod | FIRST E-Mail Blast Archive | 29 | 19-12-2007 16:58 |
| FIRST: Fwd: SolidWorks Software support for US First Teams | chris31 | FIRST E-Mail Blast Archive | 8 | 24-04-2007 15:09 |
| FIRST Software Repository - updated | roboticsguy1988 | Technical Discussion | 0 | 04-11-2006 22:54 |
