Re: chassis isolation, contrary to UL1740?
On the Power Distribution module (aka PD), there is a 1.1A (hold), 2.2A (trip) PTC (Positive Temperature Coefficient) "breaker" in the return path for the 24V supply for cRIO. That device will limit current "through" the cRIO chassis to only a few Amps.
How will we inspect for chassis isolation since every team that mounts a cRIO to a metal chassis will have an intentional low impedance connection to ground? We haven't figured out the details yet but we'll probably need to unplug the cRIO from its power supply when performing the standard chassis isolation test. Russ |
It will certainly be mandatory for any of the team I end up mentoring.
I probably should have included the following disclaimer in my above post -
I don't write the rules. It's possible that FIRST and the GDC may decide to require non-conductive mounting of the cRIO to fully avoid the issue. Russ |
Whatever the rule turns out to be, I hope that the rule makers will have it well thought out before January 3rd, 2009. |
| Chassis | Torboticsmember | General Forum | 2 | 30-01-2008 16:30 |
| Chassis info | Barak Shelef | Technical Discussion | 2 | 07-01-2007 14:31 |
| Contrary to popular opinion..."wedge" robots are out | David Brinza | Rules/Strategy | 23 | 24-02-2006 09:42 |
| Chassis? | jakey | Kit & Additional Hardware | 1 | 09-01-2006 15:10 |
| Chassis | ark_1230 | Technical Discussion | 2 | 04-09-2002 22:51 |
