Go to Post I feel there really is only one team, and the name of that team is FIRST. - [more]
Unread 14-10-2008, 21:11
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Vibrations during CNC
Does anyone have a simple way to reduce or eliminate the vibrations the CNC bit causes on a piece you're milling out? We're using C-channel for our side rails of our platform, and we're milling out holes for the wheel wells.
Near the end of the fourth run for each rectangle we cut out, the middle piece that's being cut out begins vibrating. It's not too rough, but it does cause noticable (yet tolerable) imperfections in the cut. Do we have to live with this (and file it down afterwards) or is there a way around it?
Thanks in advance.
GitHub
Unread 14-10-2008, 21:14
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Vibrations during CNC
Slow down the cutting speed.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 14-10-2008, 21:26
AdamHeard's Avatar
Lead Mentor
It's a lot more complicated than that.
There are a great deal of issues that are all combinations of the type of cutter, depth of cut, feedrate, rpm, number of flutes, cutter geometry, etc... etc...
Unread 14-10-2008, 21:27
DonRotolo's Avatar
Back to humble
FRC #0832
Clamp that part of the workpiece better.
I think what you are saying is that the waste part of the hole you're making starts jumping around, right? If so, make the cut in more than one pass - almost all the way through to start, then using only a very light cut for the finish. Or exclude the middle of the sides at first, then take them last. Or clamp the middle of the waste rectangle (drill a hole and bolt thru to the work table)
And yes, slowing down the cutting speed (not the tool speed!) may help.
Unread 14-10-2008, 22:28
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Shorter tools... but that only gets to be an issue when you're using BIG tools (1"x4" FEM or something of the like).
Mainly, clamp better. That's the biggest thing.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 15-10-2008, 01:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Thanks in advance.
A bit confused here. When you say the middle piece that's being cut out vibrates-does that mean you're cutting the outer perimeter, and a chunk is falling down through the hole you've created?
If so, super simple fix. Spiral from the inside to the outside, and then you never have a big old chunk flopping around.
If the problem is just the leg of the C chattering, that's going to be pretty much unavoidable most likely. You can try to minimize it though. Easiest thing to do would be to only conventional mill as it puts much less force on the workpiece than climb milling.
2001-2004: Team 100
2006-Present: Team 254
Unread 15-10-2008, 13:04
JesseK's Avatar
FRC #1885 (ILITE)
-- Correct --
Thanks for the tips guys, there's alot of great stuff here.
We should be able to keep the middle pieces for scraps if I bolt the middle piece in the opposite corner to where the CNC ends the final cut. For now, we'll try that on Saturday.
To clarify a bit more, we're still very new to the CNC; the teacher in the school who's an expert on it simply cannot make it to our meetings due to other things. So we're slowly figuring things out based upon emails and cautious common sense.
The way we mill things right now:
- Clamp the piece in place
- Manually zero on a reference point
- Automatically move the bit (via the "GOTO" button) to the first calculated point on the CAD drawing -- we have to manully input the X, Y, and Z coordinates
- Turn the spindle on, drill down into the metal
- Set the speeds for cutting (not sure of the units so I can't post the exact settings yet) -- It takes about 30 minutes to cut a rectangle that's 2.5" x 5" in 1/8" thick aluminum using a 1/4" bit
- Use the "GOTO" button again to go to the next point in the CAD drawings we generated
- Use the "GOTO" button three more times to finish the rectangle
So in the end it's still not a fully automated process...yet...but it's definitely an improvement in quality over what we've done in the past. We'll have our own process perfected by the time we get the first rail done, and hopefully will have more guidance by Tuesday of next week so we can do the other rail faster, more autonomously, or with higher quality.
GitHub
Unread 15-10-2008, 17:23
AdamHeard's Avatar
Lead Mentor
-- Correct --
Don't worry about keeping that piece for scrap; I would take a nicer finish with no scrap versus a small scrap of aluminum (that is probably worth pennies at most). If you start in the center and spiral out, removing all the material, you'll fix this problem (as Cory suggested... and when it comes to machining, he knows his stuff).
What kind of machine is this? 30 minutes for that much material is extremely slow.
Unread 15-10-2008, 22:16
Dowjonesbotics's Avatar
Dowjonesbotics Dowjonesbotics is offline
Leggooo
AKA: Jeremy Downes
FRC #1230 (Lehman Lionics)
Dowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the rough
Is there any other wayt o clamp it down?
My account had been hacked and used by someone random for the past 2 years, my apologies for so many awful posts.
2011 New York City Regional Regional Finalist
2009 New York City Regional Team Spirit Award
2008 New York City Regional Team Spirit Award
2007 New York City Regional Team Spirit Award
2005 New York City Regional Champion
2003 New York City Regional Rookie All-Star
Unread 15-10-2008, 22:42
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Carpet Tape+Pressure works well in addition to clamping.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 15-10-2008, 23:21
Cory's Avatar
AKA: Cory McBride
Why do you even want to keep the piece for scrap? a 2"x4.5" or so piece of 1/8" Al is fairly useless. It's almost not even worth the effort in my opinion.
2001-2004: Team 100
Unread 16-10-2008, 11:45
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
One way to reduce vibration on a leg of a C-channel would be to take a heavy C-clamp and just clamp it to the leg. This will increase the mass, hence the inertia, of the leg, thus reducing the amount that it can move or vibrate.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 16-10-2008, 14:31
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
That sounds like a good idea with the C-clamp. I would just make sure it was properly clamped/supported.
"we don't build robots, we build people"
Unread 16-10-2008, 16:00
Cory's Avatar
AKA: Cory McBride
I've done something similar to this, but put something solid (generally a 1-2-3 block) into the C on either side of the cut, and depending on what I'm doing either clamping the legs down to squeeze the block, or just sticking it in the vise if the fit is snug enough.
2001-2004: Team 100
Unread 16-10-2008, 18:41
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
what i do is just not cut all the way leave a 64 there to hole it then just punch the part out later and file the burs off
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
CNC Machines DEAL234 Technical Discussion 17 07-02-2007 16:30
CNC Options? Andrew Blair Technical Discussion 5 06-02-2006 18:12
Centroid CNC team222badbrad Technical Discussion 25 09-11-2005 20:36
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
