Go to Post "Professionalism at all times... even when you're playing an epic prank on your friends." - JVN [more]
Unread 16-10-2008, 16:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Vibrations during CNC
Originally Posted by Richard McClellan View Post
One way to reduce vibration on a leg of a C-channel would be to take a heavy C-clamp and just clamp it to the leg. This will increase the mass, hence the inertia, of the leg, thus reducing the amount that it can move or vibrate.
I've done something similar to this, but put something solid (generally a 1-2-3 block) into the C on either side of the cut, and depending on what I'm doing either clamping the legs down to squeeze the block, or just sticking it in the vise if the fit is snug enough.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-10-2008, 18:41
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
what i do is just not cut all the way leave a 64 there to hole it then just punch the part out later and file the burs off
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
CNC Machines DEAL234 Technical Discussion 17 07-02-2007 16:30
CNC Options? Andrew Blair Technical Discussion 5 06-02-2006 18:12
Centroid CNC team222badbrad Technical Discussion 25 09-11-2005 20:36
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
