Go to Post Inside Dave's Head (which is a place I'd like to go someday, but I'm not entirely sure what I'd find)... - Ian Curtis [more]
Unread 17-10-2008, 15:28
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Using an Arduino as a robot controller (2010 and beyond?)
Hi Everyone,
This post is somewhat intended to help me understand what makes the (very expensive) IFI and NI controllers superior (are they?) to the (very cheap) Arduino and it's family.
I have recently been introduced to the Arduino through the RepRap Project that i'm working on (<-- check it out!) and it seems to me that it has great potential as a cheap robot controller (which in fact is one of the major uses it is put to by hobbyists).
But before I can go out and propose that in 2010, when a 2009 rookie needs a controller for their 2009 robot for demonstrations, they can use an Arduino... I need to know if it will work!
(So for argument's sake let's just say I am proposing this, and you can explain why it won't work )
So if anyone is willing to give me a hand here with a short microcontroller primer, i'll be very grateful!
Thanks!
-Leav
p.s.
Don't you think grateful is spelled in an odd way? "greatful" would have made more sense to me
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 17-10-2008, 15:37
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
Re: Using an Arduino as a robot controller (2010 and beyond?)
Sorry that this is off topic, but no. "Greatful" would imply you are full of great; "grateful" is derived from the Latin "gratia," or kindness, friendship, gratitude. Gratitude shares the same root.
I cut myself shaving with Occam's razor.
Unread 17-10-2008, 15:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Arduinos are great fun to play around with, but they are very limited in what they can do based on their limited number of ports and processor speed. But their low (about $20 USD) price point and free, multi-platform IDE makes them very popular for hobbyists as you pointed out, who may want a cheap microcontroller for projects that don't have to generate PWM signals for a dozen motors, process lots and lots of serial communications from the radio, or handle a dozen different sensors of various kinds.
If anywhere, they may have a lot of potential in the autonomous beetleweight or antweight combat robot competitions, or in the Trinity Firefighting competition, or any other competition which deals with smaller (less mechanically complex) robots with a greater emphasis on control and sensors.
EDIT: As for whether you can use an Arduino to contro a FRC robot, the answer is yes. You can pulse the digital output ports to generate PWM signals (you'll need a 'scope though to test their waveform and troubleshoot), you can buy the RS232 serial boards for serial communications, and you can read sensor inputs. Just note that you will be very limited in all of these areas, unless you daisy-chain several together and implement a master-slave communications protocol to help they all handle different functions of the robot.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-10-2008, 15:57
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Where are the major differences that create the "thousands of dollars" difference between the Arduino and it's IFI (distant, distant) cousin?
lots more inputs and outputs? faster CPU?
(not really asking about the NI controller here cause I understand that's a whole different ball game - ARM CPU, RAM and whatnot...)
-Paraphrasing JFK
Unread 17-10-2008, 16:03
Leav - Good Question.
You could make an IFI-equivalent board from the Arduino, with a bit of work. You would need to recreate the work IFI has already done for you to do so. For one-off hack work, this is relatively easy to do. For a professional deployment to thousands of students that works as reliably as the IFI system does, this is hard.
The IFI system is based on Microchip's PIC processors, the Arduino is based on Atmel's ATmega168s. At the 50,000 foot level, these processors compete in the same field (sorta mostly kinda - close enough for the purposes of this post). One could easily argue why one is superior to the other, and either side could be right.
You certainly don't need the extra of the cRIO to drive a robot around - As Art said, you most certainly can drive a robot with an Arduino. You just won't be able to get it to do all of the cool things the cRIO can do.
Last edited by EricVanWyk : 17-10-2008 at 16:08. Reason: Leav already knows why the cRIO is happy.
Unread 17-10-2008, 16:18
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
A few things:
- The processor in the IFI controller is more powerful than the ATmega used on Arduinos, and slightly more expensive (~$20 versus ~$5 for the ATmega168 common on Arduinos).
- The IFI RC actually contains 2 microprocessors, one that is dedicated to generating PWMs, radio communication, and handling things like disabling the robot, while the other is user-programmable.
- The circuitry on the IFI RC is more complex than an Arduino. The RC is designed with things like ESD protection on the inputs, much better power regulation, etc. This stuff is what makes the RC much more robust (and resistant to electrical "oopses") than an Arduino.
- There are a bunch of different connectors on the RC. Connectors are expensive, adding to the BOM and assembly costs.
- The RC comes in a nice injection-molded case for protection.
- (Most importantly IMHO) The RC has a lot of custom software in it that someone had to write (to talk to the OI, disable robots safely, etc). Also, it had to be designed, heavily tested, and supported (taking customer calls and sending IFI reps to every event for the last 8 years). This creates a large up-front cost (to pay engineers to do this design and development) that has to be amortized across the number of RCs sold during its lifespan.
You can make the same comparisons between the new CRio and other PowerPC-based boards. The CRio is easily 10x more expensive than other PowerPC-based devices on the market, and that is probably in large part due to the level of testing, robustness, and low volume nature of the product.
Basically, the cost of these components is the price we pay for getting the kinds of features and support we've come to expect.
Unread 17-10-2008, 16:39
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
So come 2010, assuming we still use about the same amount of PWM outputs and relays, and using some sort of RF module it should be possible to do rudimentary robot control, right?
Sure, there wont any OCR (or coffee making) like the cRio can do, but a basic joysticks+basic sensors+motor outputs should be possible...
I'm generally pleased about this revelation, I'm not so uneasy about reusing the cRio anymore..... it actually makes more sense in my opinion....
-Leav
-Paraphrasing JFK
Unread 09-11-2008, 18:12
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
I'd really like to do this. The current arduino's are a little small in terms of memory and i/o ports. But, it would be fairly easy to port the arduino bootloader to a bigger AVR processor, and pretty easy to design a ifi "clone" board of sorts. I am working on a design like this in eagle cad, but it is kind of on hold right now. email me if you want the eagle files.
the difference between the IFI systems and the compac rio is betty big. one is capable of running embedded linux.
But, i still think a cheap Robotics based Freeduino should be attempted. It could be used to drive simple robots around from previous competitions. But i think it would be possible to make a freeduino controller that could be just as good as the IFI controllers.
keen101 [at] gmail [dot] com
Unread 09-11-2008, 19:06
I'd strongly recommend using Altium instead of Eagle. Altium is the best EE cad package I've used by far (and I've used quite a few of them) AND is in the kit of parts.
If you do need help with a design captured in Altium, just ask. I'd be happy to help convert you.
Unread 15-12-2008, 13:05
AndrewN's Avatar
AndrewN AndrewN is offline
it's alive!
AKA: Andrew Nicholson
FRC #1778 (Chill Out)
AndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really nice
Umm, Altium might be in the kit but I cannot get a PCB manufactured from the design and I don't have $12K to spend to get the license. I'll withdraw the comment if you can tell me how to do this for a reasonable cost.
Andrew Nicholson
2011 FRC Robot Inspector (Seattle, Portland)
Mentor FRC 1778 "Chill Out", FTC 3018, 3940 "Hawks", 4434 "Heat Misers"
"Everything should be made as simple as possible, but no simpler."
Unread 15-12-2008, 13:26
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Originally Posted by Dave Flowerday View Post
A few things:
To elaborate a little further:
If you read Wired Magazine (two issues ago) they interviewed the guys that originally designed and made the Arduino (a good article). They posted their designs up for free and allowed the community to help them design and trouble shoot all of their problems. They basically put 0 n the price for the ER&D for these. To take this into consideration, say 1 very skilled EE did all of the design for the IFI controller in 1 year. If you paid such person $50K for that year, and you sold 10,000 controllers a year, it would take 5 years to pay for his 1 year of work if $1,000 per controller was earmarked for ER&D. This is the one reason why anything well designed in low volume is very expensive.
Doing a free ER&D version and allowing the community to troubleshoot your problems works very well for hobbyists (they are forgiving of errors and bugs), but would be a huge headache for non-expert teams.
Unread 16-12-2008, 10:49
Andrew -
Your post confused me, so I chased it down with FIRST's Altium Rep. She told me that the Altium you receive in the Kit of Parts is the full blown Altium Unified Licence with a 12 month timer. This can export your board to many standard formats, including Gerbers. Gerbers are accepted by all of the board houses I've worked with, although I hear that some of the super-low-end houses only accept their own proprietary format.
If you need any help with the export/fab process, feel free to PM me or post here. Alternatively, we can set you up with the Altium Forum - the community there is on par with Chief Delphi for helpfulness (dare I say better? ).
- Eric
Unread 17-12-2008, 13:06
AndrewN's Avatar
it's alive!
Thanks Eric, I'll check Altium out again when we get our KOP in Jan.
Andrew Nicholson
Unread 28-12-2008, 04:21
keen101's Avatar
Ubuntu Linux User
I found this today. Pretty useful actually.
http://www.curiousinventor.com/kits/roboduino
however, it still has limitations, and and i am still set on attempting on creating a larger version similar to this with a more powerful AVR processor. Maybe a sanguino based version. I don't know if it's practical, but I'm still going to keep working on it, even if it only turn out to be for my benefit.
Unread 13-02-2009, 22:35
chmp09 chmp09 is offline
AKA: Marc Pulte
FRC #1702 (Robocubs)
chmp09 is a jewel in the roughchmp09 is a jewel in the roughchmp09 is a jewel in the rough
The only reason why the IFI board was so expensive is because it was made specifically for FIRST. If it were used by a wide variety of people and produced on a larger scale, then it probably would have been a fraction of the price.
'Robocup, soccerdogs, and beyond' JaneYoung Robotics Education and Curriculum 0 24-02-2008 13:44
Keeping Interest - Beyond the Robot Nica F. Team Organization 18 22-06-2007 19:16
Team 33--Above and Beyond Beth Sweet Thanks and/or Congrats 3 04-04-2005 21:55
Attn: All teams in CT and beyond. Come be scared and help some good causes!! Elgin Clock General Forum 1 03-10-2003 16:10
Fingers and Robot Controller archiver 2001 4 23-06-2002 23:54
