| Thread Tools |
Rating:
Display Modes |
Improving Solidworks Perfomance
Okey this is a Vista/Solidworks question... So if you're a computer and/or CAD wiz please make suggestions!
I've recently started using Solidworks on my laptop. I like the program, but IT'S SO SLOW!!! Everything seems to lag or jerk. I've tried lowering all the settings under the Options>Performance menu, but that doesn't seem to do much. Are there any ways I can lower the settings more? Inventor has always run just fine on my laptop, so I don't see why soldiworks should be such a strain... I'm also running Vista (yeah I know vista sucks blah blah blah, but its what I have and I can't afford/too lazy to get another OS). I've heard Vista slows things down. Anyway I can improve that? What can I change? Laptop stats: -NVIDIA GeForce 8400M -Intel Duo Core 1.83GHz -4GB of memory -HP Pavilion dv6000 |
Re: Improving Solidworks Perfomance
Make sure you have the latest drivers for your video card.
I have SW 08 on my Vista laptop. 2.4 ghz Merom Core 2 Duo, 4 gigs RAM, 8600M GT 256 MB. Runs just fine. Little bit faster than yours, but not so much so that you should be running way worse. Last edited by Cory : 18-10-2008 at 00:31. |
BTW, I have an 8200 and it works perfectly. |
Apparently I can only use HP tweaked drivers... which were last updated in 2007... stupid...
But its still a little choppy. Last edited by =Martin=Taylor= : 18-10-2008 at 01:13. |
BTW, Hachiban Nvidia has upgraded the drivers for the 8000 series and i'll see if i can find the right driver for you. Also check out the dv9000 series and they might have the right driver. It is a pain to find drivers.
turn off the fancy effects in vista, mainly desktop composition. I forget where the option is exactly, but if you turn off all that (transparency, etc) vista will be much faster.
| Improving Officiating at FIRST Events | Madison | General Forum | 87 | 10-09-2008 11:54 |
| Improving the Efficacy of a Team | Jaine Perotti | Team Organization | 5 | 24-05-2005 19:27 |
| White Paper Discuss: Team Regional Perfomance at your finger tips... | CD47-Bot | Extra Discussion | 4 | 14-04-2004 13:56 |
| Improving PBASIC: Request for Comments | Greg Ross | Programming | 19 | 16-02-2002 22:14 |
