Re: no lighted switches...
Posted by Nate Smith at 1/18/2001 12:30 PM EST
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
In Reply to: Re: no lighted switches...
Posted by Matt Leese on 1/17/2001 10:37 PM EST:
From what I've heard from Innovation First and FIRST in the past, the +5V available on the joystick ports is a very low amperage, intended only for the potentiometers within the joysticks or in a custom control box/arm/whatever...the concern was that the amperage was not high enough to reliably power the lights within a lighted switch. However, you do have the LED driver pins in two of the ports that you can wire a LED to if you want to have a software-controlled light on your operator controls...
