Go to Post The [FIRST Robotics] competition is a friendly / gentleman's sort of sport... It is only a forum to put our machines to the test, and see how well we did against what WE set out to do -- not to see which team can build the best robot. - KenWittlief [more]
Unread 23-06-2002, 23:09
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Can I use any type of switch on my controler interface?
Posted by CArobot at 1/17/2001 9:48 PM EST
Other on team #619, CArobot, from Charlottesville Albemarle.
#0047 (ChiefDelphi)
no lighted switches...
Posted by Joe Johnson at 1/17/2001 9:58 PM EST
In Reply to: Can I use any type of switch on my controler interface?
Posted by CArobot on 1/17/2001 9:48 PM EST:
I think yes. I have not read the rules that closely
yet, but I think that I recalled switches being allowed
as long as they were not lighted switches.
Joe J.
#0047 (ChiefDelphi)
Re: no lighted switches...
Posted by Brian at 1/17/2001 10:07 PM EST
Student on team #56, Robbe Xtreme, from Bound Brook High School and Ethicon Inc..
In Reply to: no lighted switches...
Posted by Joe Johnson on 1/17/2001 9:58 PM EST:
Joe,
How come they dont allow lighted switches?
Just curious
I know curiousity killed the cat or something like that
Brian
#0047 (ChiefDelphi)
Posted by Matt Leese at 1/17/2001 10:37 PM EST
Other on team #73, Tigerbolt, from Edison Technical HS and Alstom & Rochester Institute of Technology.
In Reply to: Re: no lighted switches...
Posted by Brian on 1/17/2001 10:07 PM EST:
And satisfaction brought it back. But seriously, I believe they don't allow lighted switches because of the way power is fed from the Operator Interface. First of all, if the power draw is too great then the OI might assume that the switch is tripped when it's not. The other reasoning would be that they don't allow other lights so why would they allow lights on switches.
Matt
#0047 (ChiefDelphi)
Posted by Nate Smith at 1/18/2001 12:30 PM EST
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted by Matt Leese on 1/17/2001 10:37 PM EST:
From what I've heard from Innovation First and FIRST in the past, the +5V available on the joystick ports is a very low amperage, intended only for the potentiometers within the joysticks or in a custom control box/arm/whatever...the concern was that the amperage was not high enough to reliably power the lights within a lighted switch. However, you do have the LED driver pins in two of the ports that you can wire a LED to if you want to have a software-controlled light on your operator controls...
#0047 (ChiefDelphi)
Posted by Nate Smith at 1/18/2001 12:33 PM EST
: I think yes. I have not read the rules that closely
: yet, but I think that I recalled switches being allowed
: as long as they were not lighted switches.
: Joe J.
Yep...it was originally left out of the AHL, but was added in a later update(#3 i think)...and the official ruling is any non-illuminated, non-powered switches(no, they won't let you have a keypad with a circuit between the OI and the keypad - I asked last year =) that are wired within the rules for the control system are allowed.
nate
[IMG] code is Off
3 way toggle switch programming LeadRiccardoT Programming 3 17-02-2003 02:02
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
Looking for operator interface... Where is it? mike325 General Forum 2 07-01-2003 15:28
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
is the reed switch legal? Anne Lam Technical Discussion 3 14-02-2002 12:39
