Re: cRio external 'co-processor' options
Why are people concerned about not having a DHCP server? DHCP is not an integral part of the TCP/IP stack, and can be bypassed simply by configuring a static IP address. DHCP is only used to allow more flexibility in network topology.
My assumption would be that the cRio's access point NIC would be a DHCP client and the cRio's second NIC and the camera would have static, but configurable, IP addresses. Can any of the beta teams confirm this? |
I put the attached pic together for our team. The downside to this is that it limits us to only 25499 teams. |
Three words: Downloading the Internet.
(Just kidding) But yeah, this is very nice. One possible tweak that someone might think about is designing a Bluetooth interface, then having the robot connect through someone's laptop and beam streaming video from the new cameras to a video stream server. Make it happen! EDIT: Anyone know any good whitepapers on the digital stream format the FIRST cameras send out? Last edited by ShotgunNinja : 20-10-2008 at 21:13. |
Usually Ethernet cameras use very simple protocols, often just a stream of JPEGs, but there doesn't seem to be very much standardization in this area. Coding4Fun did an article about streaming Ethernet camera data, and doing motion detection a while ago. |
#7
Here is a neat Linksys Linux robot that uses an ethernet camera. Maybe you can learn something from his project.
http://www.jbprojects.net/projects/wifirobot/ |
#8
My question with the cRio, are the teams allowed to write code directly for the FPGA? Verilog is nifty, and being able to accomplish certain tasks very fast could be win-win.
Also, where would I be able to find more information? As an Alumni I hear bits and pieces from my team, but not nearly enough and this year it looks like the control board alone is going to be pretty awesome. Also, if someone is doing motion based stuff, take a look at OpenCV from Intel. That is some cool code ![]() |
#9
Also, my understanding is that teams will NOT be able to program the FPGA directly, as that is where FIRST is storing their "master code" for the system, similar to the master CPU in the older IFI system that handled the disable codes from the field, etc. |
| Future use of cRIO? | SL8 | Technical Discussion | 47 | 30-04-2008 13:18 |
| Co-Processor? | Guy Davidson | Programming | 14 | 19-11-2007 19:31 |
| Co-processor | whytheheckme | Programming | 5 | 24-02-2007 20:11 |
| Poll: Is your team using an external processor? | Eldarion | Programming | 15 | 10-02-2006 09:51 |
