Go to Post A good measure of Integrity is what you do when nobody's watching. - DonRotolo [more]
Unread 20-10-2008, 09:49
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Vibrations during CNC
End of Weekend update:
A brand new bit was put on the CNC and we learned that the spindle speed had to be manually adjusted. So after some fine tuning of the machine and refinement of the drawings, the machine cut the rectangles in under 5 minutes each. We wound up bolting the middle rectangle on the opposite end from the final cut and it worked out beautifully.
Pretty sweet!
Now we're off to scavenge parts off of an older bot to fix the '08 bot's problems.
2017 Scoring Model
CAD Library | GitHub
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
CNC Machines DEAL234 Technical Discussion 17 07-02-2007 16:30
CNC Options? Andrew Blair Technical Discussion 5 06-02-2006 18:12
Centroid CNC team222badbrad Technical Discussion 25 09-11-2005 20:36
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
