Go to Post Robotics for me though really is hard to beat. Though tiring and exhausting, the memories you build are priceless. - ShadowKnight [more]
Unread 16-10-2008, 19:50
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Vibrations during CNC
What kind of machine is this? 30 minutes for that much material is extremely slow.
Yea, 30 minutes. After doing a bit of looking, I think the bit is either dull or isn't designed for fast cutting. It looks like a simple 2-flute square end bit. Any recommendations? I know he has a couple of bits hidden somewhere so maybe I can get him to leave them out for me Saturday.
And I want to keep at least some of the scraps simply because this is only a prototype and the rectangles are perfect for fixing up some minor problems on an old bot.
2017 Scoring Model
CAD Library | GitHub
Unread 16-10-2008, 20:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
What brand/model machine is this?
You've got the right type of end mill. 2 flutes with a square end will work fine. It may have been dull already, or you may have run it so slow that it dulled it just cutting out your pockets.
30 minutes seems absurdly slow. Even the smallest CNC mills I've ever seen (the little Taig/Sherline ones) wouldn't take 30 minutes.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-10-2008, 09:49
JesseK's Avatar
FRC #1885 (ILITE)
End of Weekend update:
A brand new bit was put on the CNC and we learned that the spindle speed had to be manually adjusted. So after some fine tuning of the machine and refinement of the drawings, the machine cut the rectangles in under 5 minutes each. We wound up bolting the middle rectangle on the opposite end from the final cut and it worked out beautifully.
Pretty sweet!
Now we're off to scavenge parts off of an older bot to fix the '08 bot's problems.
2017 Scoring Model
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
CNC Machines DEAL234 Technical Discussion 17 07-02-2007 16:30
CNC Options? Andrew Blair Technical Discussion 5 06-02-2006 18:12
Centroid CNC team222badbrad Technical Discussion 25 09-11-2005 20:36
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
