Go to Post I am the person I am because I have come to accept the mistakes I have made, not because I try to change them. - IronicDeadBird [more]
Unread 23-06-2002, 23:11
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Wiring the actuator
Posted by Patrick Dingle at 1/18/2001 3:42 PM EST
Other on team #639, Red B^2, from Ithaca High School and Cornell University.
Has anyone figured out how to electronically hook up the actuator to power supply and robot controller? Are there connectors for this or do we need to make them?
Patrick
#0047 (ChiefDelphi)
Re: Wiring the actuator
Posted by Ed Sparks at 1/18/2001 9:06 PM EST
Coach on team #34, The Rockets, from Bob Jones High / New Century High and DaimlerChrysler.
In Reply to: Wiring the actuator
Posted by Patrick Dingle on 1/18/2001 3:42 PM EST:
Use a servo cable. The female end of the cable fits the connector on the Belimo motor just fine. Cut the male end off, strip the wire and connect to the appropriate output device (spike or victor). Note that the motor only requires two of the three conductors.
#0047 (ChiefDelphi)
Posted by Nick at 1/19/2001 5:59 AM EST
Student on team #240, Mach V, from Jefferson Monroe High School and Visteon.
In Reply to: Re: Wiring the actuator
Posted by Ed Sparks on 1/18/2001 9:06 PM EST:
Which two?
#0047 (ChiefDelphi)
Posted by Ed Sparks at 1/19/2001 7:39 AM EST
Posted by Nick on 1/19/2001 5:59 AM EST:
The 1st & 2nd pins (starting from the left side of the connector on the actuator) are the ony two pins that you need to worry about. My actuator has a little motor symbol drawn above the connector at pins 1 & 2.
#0047 (ChiefDelphi)
Posted by Patrick Dingle at 1/19/2001 6:21 PM EST
Posted by Ed Sparks on 1/19/2001 7:39 AM EST:
Thanks for the info. My brain seems to be working today and it makes sense.
Patrick
: The 1st & 2nd pins (starting from the left side of the connector on the actuator) are the ony two pins that you need to worry about. My actuator has a little motor symbol drawn above the connector at pins 1 & 2.
#0047 (ChiefDelphi)
Posted by Dan Grostick at 1/22/2001 9:44 AM EST
Engineer on team #267, Demolition Squad, from North Broward Prep / St. Andrews.
For prototyping purposes, an inexpensive way is to use a modified integrated circuit socket - just cut off the extra positions. These are available at Radio Shack.
[IMG] code is Off
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
wiring. archiver 2001 1 24-06-2002 00:07
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
What is the wiring for the FESTO valve? Nuts4FIRST Technical Discussion 4 12-02-2002 17:14
