Go to Post I'd just give you the URL, but then you wouldn't learn to look for yourself. - DonRotolo [more]
Unread 22-10-2008, 19:42
gorrilla's Avatar
gorrilla gorrilla is offline
AKA: adam spears
FRC #1557 (12voltbolt)
Team Role: Driver
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: pic: Team 190's new robot
oh so you left the gray stuff on there and screwed the tread to the flat spot ok
how long did it take?
and is the rubber removable if you could just remove it all and get to the plastic rim you could rivet the tread to that right?
Unread 22-10-2008, 19:56
Francis-134's Avatar
Francis-134 Francis-134 is online now
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
It took us about 1/2 hour to cut the tread and attach it to the wheels. If you have the tools or time, you certainly could remove the gray tread from the wheel before attaching the traction material. I would chuck it in a lathe and cut it away.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 22-10-2008, 20:13
Back when 330 put tread on Skyways, we'd use a belt sander. Put the wheel on an axle (with bearings), then hold it at an angle to the sander's travel until it was the desired thickness/flatness. After a certain point, you'll hit black in spots--stop there, it's the plastic.
Unread 22-10-2008, 20:19
gorrilla's Avatar
AKA: adam spears
Team Role: Driver
oh that works cause we dont have a lathe
so then will the ifi tread work or do i have to get a special tread
Unread 22-10-2008, 20:21
IFI should work. You could also get some conveyor belting from McMaster (roughtop, wedgetop, or nitrile).
Unread 22-10-2008, 20:23
gorrilla's Avatar
AKA: adam spears
Team Role: Driver
awsome now i have something to do for a while and to clean up our wheels bin
and does anyone know why the andymark wheel is flat but the skyway is more rounded
Unread 22-10-2008, 23:50
Lifer
The AM wheels are designed for maximum traction, while the Skyway wheels are designed for wheelchairs which need the ability to turn easily and provide stability in any sort of tipping situation.
Before anyone says it, I understand that surface area is not factored into traction, but in a real-world, the non-ideal scenario, the deformation of the carpet and wheel, as well as the peaks and valleys of the carpet make surface area very important for traction. Similarly, a wheel with a larger surface area will have a higher coefficient of friction than a wheel with a smaller surface area (assuming they are the same material)
pic: Skunkworks Team 1983 NEW ROBOT FOR ATLANTA! AnthonyN1983 Extra Discussion 9 02-04-2008 21:41
Legality of Team 190's Mechanism? SU 39 Rules/Strategy 91 23-03-2008 11:43
pic: The New and Improved Team 1708 Robot! robotboy11 Extra Discussion 2 15-02-2008 14:05
pic: Team 522's new home for their newest robot Cleo Mr.T Extra Discussion 11 02-03-2005 22:45
pic: Introducing 190's M.O.H. Goat CD47-Bot Robot Showcase 24 01-03-2004 00:53
