Go to Post After all, professional engineers know The Right Way To Do It (TM) and if we knew that we'd be deprived of the educational experience of screwing up. - phrontist [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 08-10-2008, 12:27
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
State machine in LabVIEW?
Hey,
So I have been wondering...
I want to help students write in LabVIEW next year, but I really don't know it all that well myself yet.
First off, last year I had, in C, a state machine for autonomous. It was an integer paired up with a giant switch/case; there were states for "moving forward", "turning left", "short segment moving forward", etc. It worked well. But it only worked well because there was a round robin method of execution--the arm control code got executed (feedback loops for the arm joints), the drivetrain control code got executed (feedback loops for the two crab drive mechanisms), and any other support code got called, once a loop. Now that we have LabVIEW, how do I implement a similar setup?
I have seen a Case statement for LabVIEW, but does that exclude any other code that might need to be executing? I need my feedback loops in one spot, executing all the time. How are auton and teleop separated in LabVIEW?
I am trying to write up something that will at least take user controls as input (instead of encoders and sensors) and output to "motors"--indicators.
Is there a better method to learn LabVIEW?
Thanks for your help...now that I am back to being a n00b...
JBot
EDIT: For that matter, how do I regulate a feedback loop to run exactly every X milliseconds?
Aren't signatures a bit outdated?
Unread 08-10-2008, 13:06
Re: State machine in LabVIEW?
Labview is inherently parallel. If you want your feedback loops to run all the time, put them outside the case statement. If it depends on something from inside the case statement, run a wire from inside the case statement to your feedback loops outside.
See the code team 39 posted for an example: http://forums.usfirst.org/showthread...8186#post18186
See this thread on the FIRST forums: http://forums.usfirst.org/showthread.php?t=9906
Unread 23-10-2008, 00:47
Joe Hershberger Joe Hershberger is offline
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Hey,
Be warned... When you say exactly, be sure that's what you need. If you use a timed loop to do everything, you will have lots of problems. It's not like there is a turbo button on the controller and making everything on the controller high priority will keep the CPU from being lazy. Consider the timed loop to be a timer interrupt service routine. Only put the things in it that NEED to be exact... and it had better be a small amount of code.
For the general case, a simple "Wait Until Next ms Multiple" VI will do the trick. It takes into account the time that the code in the loop takes to execute and should give you a consistent loop rate.
-Joe
Unread 23-10-2008, 07:59
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Thanks for the advice.
I am beginning to understand how LabView works. It seems like there would be a way to configure the cRio to sample every x milliseconds, and that time-critical part of the code would be isolated from my user code. If that's the case, there's not much use in using a timed loop; if I write it correctly, the data flow of each sample coming in should do that.
I wish things weren't so fuzzy. Working on a beta team would have been so exciting!
JBot
Hawaii Gov. Lingle State of State speech-FIRST and STEM MoeMom FIRST In the News... 0 29-01-2008 17:04
What to machine? sanddrag Technical Discussion 8 14-06-2004 11:22
EDU Demo Code: Serial Data Transmitter Using a State-Machine Kevin Watson Programming 3 28-12-2003 22:56
machine shop?? trollin1st Off-Season Events 0 12-02-2003 21:02
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
