Thread Tools |
Rating:
Display Modes |
Re: [FTC]: LabVIEW Programming Template for FTC
We would appreciate it if you could try out the improved scaling code and see if our changes have any impact. On another note, we have noticed that many computers have trouble displaying the formula embedded in the scaling paper, so we exported it to a PDF. |
I'm wonderng what the possible differences might be. We both should be using the same NXT firmware. Did you download the recent FTC Toolkit update (released on Oct 16th)? I did, so I wonder if this could make a difference. I just installed your code right as it came, and got the delayed response. There is no doubt it's there. I wonder if the NXT internals have changed recently. When I get a chance I'm going to look at the internal Settings/NXT version info. in the brick to see how it compares with yours. Can you lookup and post that info when you get a chance? I'll try the new code when I get a moment. |
Philbot, Do you have encoders on your drive motors and are they hooked up? We don't and the new move motors vi definitely has delays if you don't have encoders. |
FW: 1.21 AVR: 1.01 BC4: 1.01 BUILD 0508081346 ID 0016530857F2 |
but it looks like there may be a fix in the works.... Woo Hoo ! |
I looked at the code and although there does seem to be a call to "GetEncoders" the call just seems to be setting some flags. No sure why it's there. The Move command is just a fixed power command as far as I can tell... not sure why there should be any extra delays... but I'll take your word for it... I gues I better test it both ways to see if I get simmilar results. Too bad if I want to drive the motors without encoders.... Phil. |
| [FTC]: First problem with FTC and LabView.....? | PhilBot | FIRST Tech Challenge | 5 | 07-11-2008 10:36 |
| [FTC]: FTC Labview questions | Monty Python | FIRST Tech Challenge | 8 | 14-10-2008 20:03 |
| [FTC]: Request for FTC video footage in Atlanta | ManicMechanic | FIRST Tech Challenge | 0 | 13-04-2008 02:27 |
| [FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) | Mr. Lim | FIRST Tech Challenge | 2 | 03-03-2008 11:54 |
| [FTC]: [FTC]: Ontario Provincial FTC Start/End Times | cbhl | FIRST Tech Challenge | 8 | 16-12-2007 13:37 |
