Go to Post ...and part of being Graciously Professional is knowing what your job is and how to perform the duties of it accurately. - jamie_1930 [more]
Unread 23-10-2008, 15:57
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Keying a UVW Map
Hi, as the title suggests, I'm having trouble keying the scale of a UVW map. When I try to, it just uses whatever size I just framed it as as a constant for the whole animation sequence. Is it just not possible/is there another tool I should be using, or am I just not doing it right?
~Setsanto
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
Unread 27-10-2008, 11:33
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Keying a UVW Map
I do not understand what you are trying to do. Tell us the effect you are trying to achieve
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 27-10-2008, 19:22
boehmz boehmz is offline
FRC #1730
boehmz is on a distinguished road
Near the big key button, there is a list of things that are effected by setting keys. Only a few of them are selected by default. Try checking each box, so that everything is affected(?effected?).
Unread 30-10-2008, 15:09
Setsanto's Avatar
Team Role: Animator
I have a UVW Mapping modifier applied to a box. The box also has a squeeze modifier on it that compresses the box and then expands it.
I have tried keying it with the gizmo under the subtree of the UVW mapping modifier selected, but it only let's me key in one direction: either the gizmo gets bigger or it gets smaller, it can't do both. Also, the gizmo does not centre around the box.
~Setsanto
Unread 01-11-2008, 19:32
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
I'm sorry man I still don't understand what you problem is or what you are trying to do. You need to point out exactly whats wrong like were idiots, otherwise were not going to understand.
Tell us what you want to accomplish. Example "I want to make egg shaped eyes for a character useing a sphere."
then tell us what your doing. example. "I created a sphere and applied the stretch modifier to it. Then I constrained the sphere to a point using a look at constraint."
then tell us what the problem is. Example "When I move the point, the sphere rotates but It keeps popping out of the egg shaped eye sockets that I made for my character."
Then ask the question. example "Is there any way to attach the gizmo of the stretch modifier of the sphere to the character instead of the sphere? That way when it rotates the polygons seem to move over the shape of the egg. Like Donald duck eyes?"
And perhaps a picture will help of what you want to accomplish.
"I want to make his eyes and have them rotate them with out the eyes rotating out of the socket."
Then you will get a good response like "Don't use the stretch modifier, use a FFD gizmo that is located in the create tab in space warps (Or helpers, I don't know, i use them all the time but I don't know where they are located unless I do it.) Place the sphere completely inside the gizmo. Then space warp bind the sphere to the FFD gizmo. Go into the lattice parameters in the FFD gizmo in the modifier stack window and stretch out the FFD gizmo.
Viola Donald duck eyes that rotate like they should"
Really try to communicate your question. I have no idea what you are trying to do with the screen shots you submitted.
A.K.A Llama
Field Map Mr. Steve Championship Event 13 13-04-2005 21:54
Keying a shaft Cory Inventor 4 08-01-2004 16:15
World Map Redhead Jokes General Forum 10 12-03-2003 10:26
Memory Map n[ate]vw Programming 1 25-01-2003 01:17
Keying it Up Ryan Curry Technical Discussion 6 26-01-2002 11:56
