Go to Post Ah, the FIRST Community, aka The Land of Little Patience :) - Jessica Boucher [more]
Unread 16-10-2008, 10:30
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
[FTC]: Anyone know the actual height of the puck rack?
Before anyone says "Read the manual"... I have, several times, and looked at the field drawings (the latest one).
The length of the rack mount, and the position of the retaining bolt is defined.
The problem is that the rack stand doesn't sit on the ground. It actually slides down and fits onto a vertical portion of the wall structure (see the slot cut in the bottom of the support).
So the actual height of the puck tube mounting bolt is 1' 6 3/8" above the bottom of the support, but who knows how high off the ground the actual support sits.
It could be 1/8" or it could be 1"
OK, I'm probably being more finiky than I should, but It annoys me that we have these "field drawings" but they don't really let you build a replica.
eg:
How high are the field sides? Show me on the drawing?
What are the specs for the mat material? brand, part number, color etc. (I know, but not because it's on the drawings).
After messing up the puck holder colors last time, it looks like they've messed up the starting position tape colors this time.
I'd post in the Q&A but it doesn't like my authentication....
It logs me in, but won't let me post... I think I'm just on too many forums
Phil.....
Phil Malone
http://www.GEARSinc.org
Unread 16-10-2008, 10:35
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
Re: [FTC]: Anyone know the actual height of the puck rack?
Phil, I think you should F/U with FIRST HQ and post this question in the Q & A so it can be answered for all.
Call the FTC folks re: posting. They need to know.
1-800-871-8326. ext "0" They will transfer you.
(I don't want to post names and ext. here).
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 16-10-2008, 10:57
PhilBot's Avatar
AKA: Phil Malone
Hi Jenny.
Sorry if my frustration is showing.
The FIRST FTC Q&A fourm just seems to move like molasses. The answers (to my early questions at least) seemed to take weeks, and then they are vague or contradictory.
FTC does not seem to be getting the same sort of QA that the other programs get. This latest change to the drawings is a good example. I know it's new and all..... but if it's hard for an nerdy all-rounder like me to figure out... I can't imaging how others are doing...
Phil.
Phil Malone
Unread 16-10-2008, 12:20
Phil,
Don't apologize for your frustration.
I still think that you need to let FIRST know.
I would also contact Jeff, the FTC partner in MD, and see if he can get some movement.
Unread 16-10-2008, 16:30
ttldomination's Avatar
Sunny
1. I understand about the FTC Q & A. It is extremely slow.
2. It would be great if you tried to post something or ask FIRST and let us all know. I tried to find out how high the little knob for the racks was, and I couldn't really figure it out. Let us know.
Thankx.
1648: 2013-2014
5283: 2015
Unread 22-10-2008, 08:19
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
I have the same issue. I went to the Delaware (in NJ) "scrimmage" which supposedly had an official field. I measured the heights of the puck racks. I came home and looked at the drawings. The total height I measured was less than the height on the drawing. But as best I could tell the bottom of the rack was very near the ground, maybe 1/16 inch off.
At this event I talked extensively with the person from FIRST that made the drawings. I pointed out the errors and inconsistancies that I had found. They were all fixed in the new release of the drawings. One issue that showed up was that there are two official versions of the field that are slightly different, not to mention the wooden version that I have!!
Jon Thompson
Coach FTC 177
Twisted Bots
Unread 22-10-2008, 10:49
PhilBot's Avatar
AKA: Phil Malone
The official Q&Q now just posted:
A1: The pivot point of the PVC mounting bolt is approximately 18.5" from the field mat. However, be aware that fields are different at all tournaments and tolerances can be +/- 1". Please design your robot with all tolerances in mind.
This jives with my "best guess" from the drawings of 18 3/8", except that I calculated from the floor and not the top of the mat.
Which begs the obvious question: Does the perimeter sit on the floor or on the mat. I've been assuming it sits on the floor.
Personally I think.. +/- 1" is a pretty wide margin on a robot with max 18" dimensions. Remember we're trying to do this is autonomous mode..
Phil Malone
Unread 22-10-2008, 14:19
VRC Coach
AKA: Jon T
All the fields I've seen the wall sits on the floor. So I think the 18 1/2" should be from the floor. I agree with you about the +/- 1" tolerence being too large.
Jon Thompson
Coach FTC 177
Twisted Bots
Unread 22-10-2008, 16:09
Sunny
Also, although the hole for the pivoting part of the puck rack may be 18.5", the actual little square piece to pull down the rack can be lower. So, it might depend.
jjbbjjt - How high was the rack's little square piece from the bottom of the floor? Did you measure from the foam tile?
1648: 2013-2014
5283: 2015
Unread 23-10-2008, 11:25
VRC Coach
AKA: Jon T
I haven't measured although I do know in DEL/NJ the pull down piece was 2" long rathar than the specified 1.5." Also on our field in my basement I have at least 1/4 " variance because the basement floor is not flat.
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
Unread 23-10-2008, 16:54
Sunny
Hm... I see that's a real problem. Anyone consulted FIRST about this?
1648: 2013-2014
5283: 2015
Unread 25-10-2008, 20:22
Carol's Avatar
Carol Carol is offline
FRC #0365 (MOE)
Carol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond repute
Geography lesson. The scrimmage (which is run jointly by a NJ and a DE team) is held in New Jersey on the Delaware river. Hence the name.
MOE 2007 Chairman's Video by MOE video team and Paul Lazarus http://moe365.org/CHMN_AWD_video_2008.php
MOE 10-Year Video Celebration on YouTube http://www.youtube.com/watch?v=ETcSMUBUqEs
[FTC]: The Rack colors addictedMax FIRST Tech Challenge 3 18-09-2008 23:06
Does anyone know the significance of the division names? Adam Y. Championship Event 2 06-04-2004 20:12
Anyone know the animation winners? (I know team 191,who else archiver 2001 3 24-06-2002 03:24
So does anyone know what the name of the new field archiver 2001 4 24-06-2002 03:01
the Puck archiver 2000 5 23-06-2002 23:08
