Re: [FTC]: Trivial things that can cause big problems.
Has anyone done servos with gearing so far? Maybe I was missing something in the way to mount them, but as soon as I tried to gear the servos for a 2:1, the spacing would not work from whatever I saw. Maybe we are just supposed to do 1:1, but I don't think my design will life all the pucks I wants to with 1:1.
![]() I remember kludging something together back then but I didn't take pictures. Bottom line: I think that the S:M and M:L gear trains can be built; but I don't thenk the result will be as elegant as the 1:1 and S:L gear trains. Maybe someone else has figured out a good way to build them? Blake |
Hm...we seem to be having trouble with the clamps for the axles as well, the axles seems right, but then it continues to slide around. I'll go back and check to make sure it's in right.
Thankx. |
I have been telling the kids not to put in all four screws before clamping to the axle. I only recommend using three so one side of the clamp will still move.
Right now we are only using two. We are running low on screws and we will be placing an order soon. When we get our roughly 300 screws in, I expect we'll put more in.
. Does anyone know where to order the large screws? Like the really long ones? |
i believe you can get them from mcmasters. they have almost all the nuts and bolts you will need, and in a higher quality metal.
#7
Are they legal? Are we allowed to purchase them?
#8
If they are identical they are legal. So they need to be the same type,size and finish. I plan to order some.
Does any one know the length of the longer screws? |
#9
They should be in the little manual. I think they're 1.25" but make sure you check. Could you post the link here after you've ordered them?
#10
http://www.mcmaster.com/ http://www.mcmaster.com/nav/enter.asp?partnum=90128A164 http://www.mcmaster.com/nav/enter.asp?partnum=90128A160 They look identical to me. |
| [FTC]: [FTC] Motor Controller problems | michael714 | FIRST Tech Challenge | 4 | 14-10-2008 00:33 |
| Things that are unnecessary | wolfj | Chit-Chat | 40 | 06-04-2008 14:28 |
| Victor failure question--Can power from motors cause them? | Kit Gerhart | Electrical | 6 | 13-12-2007 17:56 |
| Things that new members need to know about electronics | Karma | Electrical | 10 | 20-11-2006 08:35 |
| A Small Favor for a Big Cause | ComBBAT_Amy | General Forum | 6 | 30-03-2003 12:26 |
