Go to Post Real projects have good and bad aspects, problems that must be dealt with, and lots of things that dont make any sense from your side of the fence. - KenWittlief [more]
Unread 25-10-2008, 18:19
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: omni drive transmissions
Two would yield a ratio of 12.75:1, just like the toughboxes (both are made up of 14:50 reductions).
Torque/speed is still very much a concern. If you gear it too high, accelerating will take forever and low speed movements will be hard to control.
I have never built an omni-wheeled drivetrain, but I imagine directly driving off of two stackerboxes two 6" omni wheels would yield a decently fast drive, probably around 9 fps (assuming that at free speed, it'd be just shy of 11 fps).
oh i must have missed that day in math class
so your saying that two stackers is just like one toughbox in that case it should be around 12fps depending on how much wheel slip there is
and i was under the impression that if you have it geared high it would have less torque(therefore less wheel slipping) but a higher final speed or am i backwards? or is it like this because there omni wheels?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 25-10-2008, 19:15
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Higher torque=faster acceleration, more power at low speeds, easier turning(this last point is less of a concern with omnis)
Higher speed=higher top speed
Since most FIRST bots don't have much room to move or much time to accelerate, a top speed over about 11ft/sec is usually excessive.
Wheel slipping has to do with how "sticky" your wheels are. If you have more torque than your wheels' "stickiness" can transfer to the floor, and then your wheels will slip. Though lower torque reduces the risk of slipping, it also reduces maneuverability, pushing power, etc. I don't know much about the AM omni wheels, but an omni wheel should be designed to be very "sticky". (Regular wheels must slide sideways to turn, omnis don't.) Perhaps someone could enlighten us as to the sliding characteristics of the AM omni wheels.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 25-10-2008, 19:27
gorrilla's Avatar
AKA: adam spears
also is there a way to make them stickier
Adam Spears
Omni drive Laaba 80 General Forum 12 25-02-2008 01:56
Lego Omni Drive Synergy1848 Robot Showcase 19 03-01-2007 11:51
Four Wheel Drive Using Standard Transmissions daviamp Technical Discussion 4 18-01-2006 20:03
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
Image Discuss: Transmissions and Drive Train CD47-Bot Extra Discussion 16 17-02-2003 22:11
