Go to Post If the left side of your brain controls the right side of your body then left handers are the only ones in "their right mind". - Al Skierkiewicz [more]
Unread 25-10-2008, 22:53
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
NuVinci CVT Developers Kit
Fallbrook Technologies has announced that a NuVinci CVT Developers Kit will be available for $595 starting in December specifically designed to assist hobbiest in development of Light Electric Vehicles (LEVs).
Press Release: http://www.fallbrooktech.com/05_Pres...s_Intermot.asp
I'm sure hoping we see these in the KoP next year!
Unread 25-10-2008, 23:16
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: NuVinci CVT Developers Kit
hah wowo i was just talking about a cvt transmission at tnt!
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 26-10-2008, 21:58
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
While CVTs are often use in industrial equipment with Fixed speed AC motors, you don't often see them in EV aplications because an Electric vehicle motor has the properties that a CVT typically has. Usually with a 2-3 speed transmission you can get all the performance and efficiency you want/need. Also, CVTs are are typically a double edged sword on the whole efficiency thing. Almost all use a cone, ball, or belt and sheave system that invariably has a little bit of conflicting friction at the contact patch. This friction tend to make CVTs have a lower prowerr transmission efficiency. Where they do a lot of good though is with motors that have a very narrow band efficiancy range (think A/C motors, or some genertator or governed engines). On these applications the CVT can vary output speed while the motor stays in it most efficient or powerful state.
I am a huge fan of CVTs and even designed a new one while in college. If you want a great CVT design resource check out:
"Traction Drives: Selection and Application [Hardcover]
By Frederick W., III and Shube, Eugene E. Heilich"
This is a great book that devotes 50% to fixed ratio traction drives (think gear systems without teeth), and 50% to all metal CVTs (sorry no rubber belt system).
Unread 26-10-2008, 22:16
Joining the 900 Meme Team
FRC #0079
I can vouch for that book, very informative, I was curious how they worked and the book did a wonderful job explaining the concepts to me, a very non technical person.
Unread 27-10-2008, 10:55
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
I was a little bummed that they didn't cover the rubber belt systems used in Snow Mobiles and lots of different machinery, but otherwise though it was a great book.
Unread 27-10-2008, 10:59
REVving up for a new season
FRC #2848 (All-sparks)
I got to see this at the makers faire and while it is a cool technology it is very inefficient. They wouldn't tell me the exact amounts but hinted it was not good. Also the ratio range was 3:1 so it would be just a little more then an andymark from top to bottom. I think it would be cool to play with one of these but putting it on a robot doesn't make any sense.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
openFIRST looking for developers Astronouth7303 Website Design/Showcase 1 23-06-2007 22:48
New Developers Needed Astronouth7303 FIRST-related Organizations 0 03-02-2007 19:53
CVT gfreeman9mm Kit & Additional Hardware 6 09-01-2007 20:30
Cvt Jack Technical Discussion 4 05-10-2002 20:59
CVT Clark Gilbert Chit-Chat 10 11-05-2002 19:38
