Go to Post Patience is the key to FIRST. - Pavan Dave [more]
Unread 25-10-2008, 16:24
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
[FTC]: Team 35's Servo Test
We were a bit skeptical about using the servos for anything serious, articulating arm joints for example. After our first 5 hour meeting, we are VERY excited about this new kit. We brainstormed, and then prototyped 3 different ways of articulating joint for our arm. One powered by servos, one powered by 2 Lego motors and another powered by one of the larger FTC motors.
I'm posting a Video of the servo test. We attached the bracket to the frame of last years VEX 'bot for this test. The programming was a tad off for this video (we couldn't keep the arm at any angle we wanted). It was fixed later on, but i didn't get my lens on it.
http://www.flickr.com/photos/wilsonm...7608365268449/
Unread 25-10-2008, 17:38
ttldomination's Avatar
Sunny
Re: [FTC]: Team 35's Servo Test
how heavy is ur chassis approximately???
1648: 2013-2014
5283: 2015
Unread 26-10-2008, 00:52
dickswan dickswan is offline
dickswan is an unknown quantity at this point
[quote=wilsonmw04;772030]The programming was a tad off for this video (we couldn't keep the arm at any angle we wanted). It was fixed later on, but i didn't get my lens on it.
QUOTE]
If you're using ROBOTC, it has a really nice PC window that allows you to manually set the position of any of the six servos by simply entering the value into one of six text boxes. This makes it really easy to determine the 'min' and 'max' values for a servo movement.
Unread 27-10-2008, 11:30
wilsonmw04's Avatar
Coach
with the servos and stock attached: 4.676 lbs.
it's not lifting the whole weight so that's a tad deceiving.
Unread 27-10-2008, 20:35
Sunny
That's still pretty nice.
1648: 2013-2014
5283: 2015
Unread 27-10-2008, 20:37
Sunny
Well, sorry bout the double post, but 35 rings are about 6.5 pounds. With a couple o' gear reductions.... I see potential.
1648: 2013-2014
5283: 2015
Unread 28-10-2008, 11:15
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
Remember with a gear reduction of two the servo only goes +/- 45 degrees. with a ger reduction of three that would be +/- 30 degrees.
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
Unread 28-10-2008, 13:24
Sunny
Touche, well, there are other ways to get the mechanism up without even gearing the servo. Heck, if you wanted, you could gear the servos for speed. .
1648: 2013-2014
5283: 2015
Unread 03-11-2008, 11:10
wilsonmw04's Avatar
Coach
A quick test of a 4-bar linkage with the new 2008 FTC kit. The programing is a tad off, but it does give you an idea of the power of the servos and the possibilities of the new kit. The arm was made with two 16" C-channel and a 6" short member. Our final arm will be shorter, but will look a lot like this.
We are now working on programing that does not relate stick position with servo position. We would like to have the servos act more like a motor, so that when we take our hands off the stick the arm stays where we want it rather than returning to the neutral position.
Unread 03-11-2008, 18:04
Sunny
Interesting, very nicely built. A few quick questions.
1. was the tower attached or were you or someone holding it in place?
2. More of a suggestion, you could have the joy stick value *add* to the position of the encoder instead of setting the joystick value to the value of the servo.
For example:
servovalue = servovalue + joystick value;
Servo[a] = servovalue;
Where the joystick no longer equals the position of the servo. Simply changes the position.
1648: 2013-2014
5283: 2015
Unread 03-11-2008, 20:07
wilsonmw04's Avatar
Coach
It was attached to the front of the frame straight to the C-channel. This was not intended to be permanent, just a proof of concept. The Kids are working on a working mount as I type.
Unread 03-11-2008, 21:47
Sunny
It looks REALLY good and powerful. :d.
1648: 2013-2014
5283: 2015
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: Starting a New FTC Team addictedMax FIRST Tech Challenge 11 20-08-2008 10:32
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
pic: FTC 35's prototype for 2007 wilsonmw04 Extra Discussion 2 08-11-2007 18:38
