Go to Post In the end, people can throw all the stories at me they want, but I'm never going to let mere stories convince me physics is wrong. - AdamHeard [more]
Unread 24-10-2008, 20:33
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
pic: Concept 8wd Drivetrain
Unread 24-10-2008, 20:52
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: pic: Concept 8wd Drivetrain
Couple of questions:
1> HDPE is rather slick, are you planning on covering it with roughtop?
2> Are the center 4 wheels lowered? If so, by how much/. If not, how are you overcoming friction?
3> Whats the diameter of the wheels and whats it's expected speeds?
___________________
- Tennyson, Ulysses
Unread 24-10-2008, 23:25
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
I'll let sdcantrell56 answer officially for himself,
but I'm pretty sure there is a tread on the wheels already (If you look closely). I think he meant that the hub itself was made out of HDPE. The two sets of center wheels also appear to be slightly lowered by my eye, but I could be fooling myself. The wheel diameter looks to be 4".
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 25-10-2008, 01:35
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Quick Question, why not uhmw for the wheels. Just wondering, I've heard of teams having success with them.
-rc
R.C.
MadTown Robotics Team 1323
Unread 25-10-2008, 02:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Nice work on the approach and departure angles. I really like that. Every year we've ever had something to climb, it pains me to see teams with huge wheels that still can't do it, because the wheels are not positioned well in relation to the frame.
Robots don't always need large wheels or high ground clearance to climb things. This design is a fine example.
Unread 25-10-2008, 02:18
AndyB's Avatar
AKA: Andy Burchardt
-rc
UHMW and HDPE are two very similar materials. They do have differences though. HDPE stands for High Density Polyethylene which is long strands of ethylene monomers. UHMW-PE (Ultra High Molecular Weight Polyethylene) is similar, but has even longer monomers, generally making it stronger with better wear properties. HDPE will hold it's shape a little bit better and some argue that it can be machined easier. UHMW tends to be a bit more expensive than HDPE depending on the scenerio.
Honestly, when it comes to something like a wheel, using one or the other shouldn't make a big difference. It probably comes down to what you can get your hands on easier.
Unread 25-10-2008, 03:20
R.C.'s Avatar
Thanks for clearing that up, I wasn't sure what the difference was. Does anyone know how long those wheels last and nice job on the drawing and I totally agree with Sanddrag.
R.C.
Unread 25-10-2008, 12:04
AKA: Sean
Ok I will try to answer everyone. First of all I was planning on UHMW for the wheels. Something about having 2 hours of sleep made my brain function...well not function at all actually. Also the center wheels are lowered .175 inches for easy turning. The wheels are 4.5" diameter with roughtop tread. One of the nice things about using uhmw is we can buy enough material for 20 wheels for right around $70 dollars. From what I have heard UHMW makes a very durable wheel. It is stronger in impact situations and easier to attach tread (sheet metal screws). I will post up a picture of the wheel assembly with sprockets later but the entire thing with rim, tread, 2 sprockets, and 3 bearings weighs .5lbs.
Right now the speed is set right at 5fps and 14fps although that can easily be changed by switching the drive sprockets. Needless to say this drivetrain will not be getting pushed around.
Sandrag thanks for the compliments. I'm thinking there will be some type of obstacle next season and I hate big wheels so this is the result.
Mentor 2415
Unread 25-10-2008, 17:22
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
besides traction, what does a 8WD offer that a 4 or 6WD doesn't offer? To me it just takes up extra weight, but that's just me.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 26-10-2008, 01:41
AndyB's Avatar
AKA: Andy Burchardt
If UHMW is buoyant (which I have absolutely no clue), it would aid in keeping it afloat in next year's water game...
Other than that, it's pretty much traction. Also, there is less "rock" to the chassis as 2 sets of wheels are lowered instead of just 1. This could make the turning a little more stable, but I don't really think it's too big of an issue.
I would recomend going with 6wd, with a couple idler wheels that don't contact the ground to avoid rubbing on the bottom of your frame on a ramp (that is, if there is a ramp.) 8wd is really just a design choice. There is an added coolness factor as well which I think should be factored into any design decision.
Unread 26-10-2008, 10:48
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
well i know that 1251 had an 8 wheels and they did great but they were pretty easy to move, maybe not the wheels, and maybe the weight of their robot, or the distribution of their weight towards the front but i think most robots have this problem unless the have a good weight distribution over the right places
having lots of traction dosent matter if you have all the weight in the wrong places
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 26-10-2008, 11:13
AndyB's Avatar
AKA: Andy Burchardt
Keep in mind that increasing the number of wheels will no gain your more traction. You'll get the same traction out of a 6wd that you will out of an 8wd. At least theoretically.
You may gain some traction if using wedgetop tread due to it's 'stickiness'. You may also gain traction from using roughtop tread which will actually cling to the carpet. These situations are both relative to a similar setup with less wheels.
The tread you are using looks like standard rubber, unless you are using something else and just didn't model it, which is completely understandable. If you are using this tread, you will likely gain little to no advantage in traction over a 6wd.
Unread 26-10-2008, 11:23
gorrilla's Avatar
AKA: adam spears
well i also dont see why teams are usig such small wheels all the time there cant be any benefit except maybe weight
Adam Spears
Unread 26-10-2008, 11:44
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Exactly, why use larger wheels when you can save 2-3 pounds and have the same functionality? Not to mention money.
-Vivek
"we don't build robots, we build people"
Unread 26-10-2008, 11:47
gorrilla's Avatar
AKA: adam spears
well do you think its really worth it i mean 1557 was 119.1 pounds and that was mostly in our frame and scissor lift
and with smaller wheels wouldent you have less traction because of less surface area
Adam Spears
pic: Concept Mecanum Drivetrain sdcantrell56 Extra Discussion 10 07-02-2008 11:56
8WD drivetrain? David Sherman Technical Discussion 16 09-04-2006 17:32
pic: Concept Gearbox Bill_Hancoc Extra Discussion 12 17-11-2005 20:54
pic: Claw^2 Concept CD47-Bot Extra Discussion 8 06-02-2004 14:08
pic: Crab Concept 6 CD47-Bot Extra Discussion 13 14-11-2003 22:03
