Go to Post I like the gearboxes that can move my mechanical systems reliably. - Ginger Power [more]
Unread 23-06-2002, 23:13
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: confuzzling gear ratio definition.. wanna clear this one up?
Posted by Mark Garver at 1/19/2001 9:49 AM EST
Student on team #68, Truck Town Terror, from Waterford Kettering/OSMTech Academy and General Motors Truck Group.
In Reply to: confuzzling gear ratio definition.. wanna clear this one up?
Posted by Anton Abaya on 1/18/2001 11:04 PM EST:
You are right, it would be a 2:1 ratio. And for the most part you wouldn't want to gear the drill motors up. I am guessing that you were in low gear last year and you used about 8" drive wheels? if you did this you would travel at about 6 feet per sec. (if i did the math right). If you are in low gear the speed of the output shaft is about 400 rpm. If you are in high gear the speed of the output shaft would be about 1200 rpm. I hope this helps answer your question.
[IMG] code is Off
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
